Results 1 to 8 of 8
Thread: start up and robot
    start up and robot
    Just opening my pool. I have a new Blue Pearl and was wondering when I should start using it? Do I need to wait until the water is clear, or go ahead and put it in to help clean?
    IG 30,000 gal vinyl
    sand filter
    1.5 hp 220 volts
    30,414
    Re: start up and robot
    If your pool is an awful mess with tons of leaves, solids, etc., the Blue Pearl (or any cleaner) will be overwhelmed. Get out ALL the solids that you can rake out with a leaf net and then put your robot in there.
    If it gets clogged up from too much junk, mine cuts off before the 90 minute cycle is up and I have to clean the bag and then restart it.
    I dont have alot of solids, mainly just dead algae. Thought it might help keep it stirred up and filter out better? Just worried at this high chlorine level it might damage the bot?? Thanks for the reply.
    IG 30,000 gal vinyl
    sand filter
    1.5 hp 220 volts
    30,414
    How high is it?
    Free chlorine is 8
    IG 30,000 gal vinyl
    sand filter
    1.5 hp 220 volts
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Should be fine. Should be able to use the bot at full mustard levels also.
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    Robot should be fine. Just remember to take it out and give it a good rinse with a garden hose.
    Had more leaves than I thought. Only ran for a few mins then kicked off. Guess I better dig most of the leave out first?
    IG 30,000 gal vinyl
    sand filter
    1.5 hp 220 volts
