Thread: Pal Treo / WIRTRAN Wiring
    Have new fiberglass pool install beginning today. I have 3 Pal Treo 5w lights and the basic WIRTRAN power panel. I'll hard wire with conduit the WIRTRAN to the EasyTouch panel. For the 3 Pal Treo lights (2 wires) do I connect + and - to each other other and to the WIRTRAN? The WIRTRAN has only one power out (30 Watt capacity).
    N Virginia
    -Leisure Moroccan 38' Fiberglass
    -19,800 Gallons
    -Pentair EasyTouch 4 w/IC40 Chlorinator,VS3050 Pump, Clean&Clear Plus 320 Cartridge Filter,Prowler 720 Robot Cleaner
    -1 Skimmer/ 3 Returns/2 Drains/2" Piping
    -3 Fiberstar Pal Treo LED lights/Wirtran
    -TF100 TestKit
    Re: Pal Treo / WIRTRAN Wiring
    That sounds right. It is fine to power all of the lights from one power supply as long as it has enough watts for all of them together.
