Results 1 to 14 of 14
Thread: Help with Chlorine Question
    Nov 2007
    Katy, Texas
    25
    Hello everybody,
    I have a question about chlorine.
    My pool is new (finished in January 07) and my chlorine seems to be too low. I am using a salt water system and my salt level is 3750PPM with my chlorinator running at 40%. Do I need to up the percentage on my chlorinator to get my TC to come up?
    Air Temp:75 Degrees
    Mostly Sunny
    FC:3
    CC:3
    TC:0
    PH:8+
    Alk:140
    Salt:3750
    32x20 Freeform (17,500 gal.) Inground pool Depth: 3-4.5-8 ft. Pentair 400k BTU heater, 320 Chlorinator, 420 Cartirdge filter, Easytouch wireless controler. Whisperflo 2hp circ pump, One main drain. 12" raised spa w/6 jets. (spillover) 750 sq. ft. stamped concrete, 6 ton moss rock waterfall with weeping rock wall, Whisperflow 1hp. waterfall pump. PCC2000 in-floor cleaning system, WetEdge Primera Stone "Tahoe Coast"
    Guest
    I did not see your CYA level nor our calcium hardness. Please post that. Also. FC+CC=TC so your FC 3 ppm, CC 3 ppm and TC 0 ppm is impossible! Your pH and your ALK are both too high for a salt pool! Please read this sticky on water balance for a SWG.
    How are you testing your water?
    tagprod's Avatar
    Jul 2007
    Tomball, Texas
    489
    I think you have your TC and CC's backwards. Get that PH down and post a CYA reading. Maybe someone can post some insight into that brand of Chlorinator - I'm not familiar with it, but yes if you turned it up to say 60% it would produce more chlorine.
    Brian
    20K IG Gunite w/ raised 7ft spillover spa. 1.5 HP Hayward Northstar pump 425 sq ft Hayward cartridge filter, Colorlogic lights AquaRite SWG AquaLogic PS-8 control
    1hp pump for sheer descent
    Yes, when FC is too low you raise the SWG percentage. When FC is too high you lower the SWG percentage.
    I notice that your PH is 8+. You really want to keep your PH below 8.0 at all times.
    Also, you list CC as 3 and TC as 0. Since TC = FC + CC, that isn't possible. Hopefully you meant to say that CC was 0 and TC was 3, in which case everything is fine. If CC is really 3 then you will need to shock the pool.
    And finally, you didn't mention your CYA level. If you continue to have problems with low FC levels you need to check your CYA level.
    Nov 2007
    Katy, Texas
    25
    I'm using a Taylor K2005 Kit.
    My Kit instructs me to take the FC-TC for the Combined Chlorine.
    I did invert the numbers on my last post so here are the correct numbers from my test today. I have been adding 1/2 gal of muradic acid every other day to try and lower the PH.
    FC: 3
    TC: 3
    CC: 0
    PH: 8+
    Alk 140
    didn't check for CYA. (out of reagent)
    Here are my numbers from a couple of days ago if that helps.
    FC:3
    TC:3
    CC:0
    PH: 8+
    Alk:150
    Cal: 180
    CYA: 45
    30,404
    Brent,
    Your pH needs to come down more quickly than you are doing. I'd suggest adding 1/2 gal followed by 1/2 gal again in an hour and again in another hour (testing each time, pump running) 'til you get it off that 8.0+ mark.
    I assume 8.0 is as high as you can measure so you have certainly been much higher than that and may still be.
    Mar 2008
    Maryland
    56
    If your CYA is ony 45 then your FC is not that low. Bump up the percentage a bit until you get to about 5 ppm. With your SWG at 40% it is creating chlorine for about 24 minutes every hour. Try bumping it up to 50% (30 minutes/hour) and after a day see where your FC is. Definitely get your pH down. Chlorine is VERY ineffective at that high of pH. Try to get the pH to about 7.2-7.4. With a SWG you will be constantly battling a rising pH.
    Nov 2007
    Katy, Texas
    25
    Thanks for all the help. I will up the percentage on my SW generator and add acid more frequently. I will post again when I get my numbers in line.
    The Sticky was also a big help!
    Thanks again!
    30,404
    Brent,
    I really didn't notice the size of your pool 'til now. 1/2 gal of muriatic should have moved your pH VERY significantly....like .6 or more. Something isn't adding up unless your pH was completely thru the roof. How many times have you added 1/2 gallon?
    Make sure you are testing correctly and have good reagents. If you're using strips, take a sample to the pool store and get it tested. I would not add more acid 'til you are sure of your test results.
    Nov 2007
    Katy, Texas
    25
    I have been testing the water every 4-5 days and adding a 1/4 to 1/2 gallon of acid every time I test (since Feb 08). My Taylor K-2005 kit consistently reads 8+ PH when I test. The color is a little darker than the marker on the tester. (The marker only goes to 8.)
    I tested the PH again this afternoon and it read 7.6. I then took a sample to my pool store and here are their results....
    Temp: 85
    FC:4.0
    TC:4.0
    CC:0.0
    PH:7.6 ( after adding a 1/2 gallon of acid yesterday afternoon with readings at 8+)
    Hardness:180
    Alkalinity: 110
    CYA:50
    Phos:300
    Salt 3700
    I upped my chlorine generator to 50 but not sure if I really need to. How else do I raise my CC?
    It is fairly common for PH to rise like that, particularly with TA as high as you have had it. You need to add more acid so that the PH doesn't get above 7.8. Try to keep the PH between 7.2 and 7.8. If you add enough acid to bring the PH down to 7.2 then you should be able to go about the same amount of time and only have the PH go up to 7.8.
    You don't want to increase CC, you want CC to stay at zero. You do want to increase FC slightly. You do that by increasing the SWG percentage, just as you have already done.
    It would be better if you increased CYA a little, to somewhere between 60 and 80, by adding some stabilizer. That would allow you to lower the SWG percentage while maintaining the FC level, reduce the rate at which the PH rises, and increase the cell life of your SWG.
    Nov 2007
    Katy, Texas
    25
    I will keep a closer eye on my numbers an add acid before my PH get above 7.8 .
    I appreciate everybody's help, you folks are a blessing!
    Guest
    Quote Originally Posted by Bgraeter
    That should be TC (total chlorine) - FC (free chlorine) = CC (combined chloramines) FC is always going to be equal or less than the TC and CC cannot be a negative number.
    Nov 2007
    Katy, Texas
    25
    Waterbear,
    You are correct...I guess I've had too many cold ones or been in the sun too long!
    Thanks!
