Thread: TA under 20, how to raise it after no drain acid wash
    solarboy's Avatar
    Aug 2010
    Europe
    337
    Hi again everyone. I recently did the 1st test of the season and i realised that my TA has dropped to 0-20. I'm guessing this is because each time my solar heating switches on it injects a load of air into the pool causing aeriation and loss of carbonates.
    Anyway, I've started a no-drain acid wash try to clean off some iron oxide staining and dropped the pH to 4 and scrubbing like mad.
    My question is this; what is the best method I could use to raise the TA back up to at least 80 (to keep my CSI in range) once I let the pH drift back up (as it has a tendency to).
    I was thinking of using Bicarb of Soda but I thought it best run it by you experts first.
    Self built 5500 gallon bare concrete (temporarily) pool with limestone coping, Pentair Swimmey 1/2 HP pump, Triton sand filter with DE, Simpool peristaltic muriatic acid pump with pH sensor and Monarch SWG. Home made solar heater with Pentair Compool control panel and 3 way valve. 1 skimmer, 1 main drain, 2 returns, 2" plumbing, Hayward auto fill valve.
    Re: TA under 20, how to raise it after no drain acid wash
    It depends on how low your PH is right now. If your PH is more or less normal the Bicarb of Soda is great. But if your PH is really really low (as it sometimes is after a no drain acid wash) then you want to use borax or soda ash.
    solarboy's Avatar
    Aug 2010
    Europe
    337
    Thanks for your swift reply Jason. I only have Boric acid available ( and my borates are at 50 already where I would like them to stay).
    I do have "Sodium hydrogen carbonate" available. Would that be any good if the pH is really low (for example 4) ?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    It's not going to raise your pH real quick, but it will raise your TA.
    solarboy's Avatar
    Aug 2010
    Europe
    337
    Thanks "Melt in the sun", just what I need to know.
    "Sodium hydrogen carbonate" is baking soda (sodium bicarbonate). After adding it, aerate to outgas the carbon dioxide.
    Support the site
