Thread: ph problems with SWG
    Installed a SWG in December and have been having troubles maintaining pH. It just keeps creeping up.
    First a little history. I bought the house 2 years ago and hired a pool guy to maintain it. I simply didn't have the time and it was something easy to outsource. When other home improvement projects started tapering off, I took over the pool maintenance, but by then the damage had already been done. CYA levels were through the roof, well over 150.
    So after reading up on SWGs, decided I needed to have one. Installed it and drained the pool. I've been cautious on CyA though as I do not want to repeat the scenario where CYA is so high that I have to drain and refill.
    Water chemistry is approximately:
    FC - around 4ppm typically
    pH - typically 8+
    TA - 70-80
    CYA - 50
    Salt - 350ppm
    Borates - 50ppm
    So I'm guessing my CYA is too low? Based on this I'd say so - pool-school/water_balance_saltwater_generator
    Does it really need to be in the 60-80 range with the constant chlorine production from the SWG while the pump is running (6 hours per day during daylight hours)? My usual problem is I get the pH down to 7.5 with acid and then a week later it is back up to 8
    22,551
    Re: ph problems with SWG
    It's common to have rising pH with a swcg. You can try lowering your TA to about 60 and raising your CYA up to 70. Raising the CYA up to 70 will allow you to turn the swcg down a bit which will in turn, not raise the pH quite as fast. Also lowering the TA will help the outgassing which raises the pH.
