Thread: Liner shrinkage
    May 2011
    Woodslee, Ontario Canada
    26
    Liner shrinkage
    Opened pool cover to find water level. Very low almost to bottom of shallow end and the liner is still attached all around but the sides are bowed in. Liner is close to 20 yrs but hoping for another season or two. Any suggestions. I found leak (I think) and patching.
    14X28 inground Vinyl
    1HP Super II Pump
    200lb Sand filter
    Tri-chlor, bleach shock
    BBB
    22,551
    Re: Liner shrinkage
    Is it water or air behind the liner?
    Either way you should be able to fill it back up and the liner will press against the walls.
    May 2011
    26
    Re: Liner shrinkage
    It is just air. Worries that age of liner, probably not much strech left in it. Will fill and hope for the best.
    Thank you sir!
    1HP Super II Pump
    200lb Sand filter
    BBB
    May 2011
    26
    Re: Liner shrinkage
    Pool filled all is good! Thanks Mod squad!
    1HP Super II Pump
    200lb Sand filter
    BBB
    22,551
    Re: Liner shrinkage
    Glad it worked out for you.
