Results 1 to 11 of 11
Thread: How do I mark posts as read?
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    On most forums, I have the ability to mark all posts as read, so i can start with a clean "View unread posts" slate, as it were.
    I don't see that option here at TFP...furthermore, reading a post doesn't seem to remove it from the "View unread Posts" list.
    What am I missing?
    -Gordon
    Pool School helps me maintain my 13,500G 24' x 48" ASP with Sand Filtration using a TF100 Test Kit and Pool Calculator.
    Remember, the Shock Process should be followed until : 1. CC is less than 0.5 ppm, 2. An OCLT shows a loss of 1.0 ppm or less and, 3. The water is crystal clear.
    --I didn't buy my pool to swim in it. I bought my pool to watch my wife swim in it. :wink:
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: How do I mark posts as read?
    The "mark forums read" link on the right side near the bottom of the index page should do it.
    22,537
    Are you logged in when this happens? If so clear all troublefreepool cookies.
    There's also a Mark Topics Read in each individual section in the upper right hand corner above the frame.
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    Quote Originally Posted by Melt In The Sun
    Ah, that was indeed what I was looking for. Just expected it to be present elsewhere. Thanks!
    -Gordon
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    How would I mark unread posts in the View unread posts link to be read rather than going to each of them?
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    Oct 2009
    3,899
    Open each in a new tab and just close it, I guess.
    Dec 2010
    560
    Yep, that's no fun... that would be nice to have the same configuration as you find within the individual forums.
    TFT-100 test kit
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    That, very specifically, is what is NOT working for me. And yes, I'm logged in, and have cleared cookies and all that happy stuff.
    -Gordon
    30,395
    This may help.
    I log on and look at the "new posts by date". I then browse those, reading only the ones I want to. Then when I am done with that session, I Logout manually.
    When I am ready for a new session, I log back on, select, "New posts by date" and it only shows me those posts that are new since I logged out.
    Not exactly what you are asking for but it's a good way to browse the forums.
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    This may help.
    Ick. Logging in and out every visit would drive me nuts.
    Could we perhaps add the "Mark forums read" link to the bottom of the "View unread posts" results page? That would make life soooooo much simpler.
    -Gordon
    30,395
    It is one click both ways.
