Results 1 to 9 of 9
Thread: New cell- false low salt
    After learning the hard way not to trust the reading from the control panel, I have realized that my AquaRite T Cell15 was dead and my pool was way too high in salt. The salt situation has been corrected and I am now at 3400 ppm. I bought a Compupool generic replacement cell for the system and installed it a few days ago to find that it reads 1200 to 1400 ppm. That low salt level shuts off the system every time. I have attempted to recalibrate (take instantaneous salt reading) the cell but it wont climb above 1400. I did notice that while the voltage appears to be in the appropriate range (24 to 25V), the amps run about 3.2 to 3.6A. What I cant determine is what the cause is. Compupool dismisses this as a control panel problem, Hayward claims that if the panel is able to run diagnostics and provide readings, then the problem must be a compatibility issue with a generic cell. Im at my wits end with all of it. Any help would be appreciated. Thanks in adavance.
    Pool size - 34,000 gallons
    14100 Gal IG MiniPebble, Pentair Intellichlor IC-40 SWG, Sand Filter, Pop Up Cleaning 1/4 Acre Desert Landscaped, Lots of Deck. Built in 1984
    "If you don't measure it, you can't manage it!"
    38,301
    Re: New cell- false low salt
    Sorry I am not really sure what to recommend. The problem is that it is always going to be the other guys fault.
    Hopefully this bump will help to generate more comments.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Sorry you are having issues with your new generic replacement cell.
    I just replaced my T-15 cell. You are confirming my decision to not buy a generic unit, even though it was a bit cheaper. Compatibility was my major concern.
    chiefwej
    Nov 2007
    Rockland County, NY
    65
    What did you use to determine salt levels? I have found those test strips to be wildly inaccurate at times. Do you have a friend or neighbor with a similiar system so that you can borrow a cell that you know is working? I think I even remember Leslie's will check out a cell no charge or may even loan you one so you can determine what is not working.
    27ft Above Ground Pool
    Sand filter
    Leslie's has checked my salt level multiple times and also confirmed my old cell is dead. Compupool is sending me a replacement cell.
    Aug 2011
    Texas
    45
    Do you have a salt test kit? I've noticed mine reads lower than what my Taylor salt test indicates. Usually the cell reads about 200 on the low side depending on water temp as well.
    12k gal gunite, Sunstone Plaster, Pentair IntelliFloŽ VS+SVRS Variable Speed Pump, Pentair Intellichlor IC-40, Pentair CCP520 cart filter
    When the old cell was still working, it typically measured about 400 ppm low, which isnt unusual. This new cell is reading less than half of the actual salt content. After a third conversation with the cell manufacturer, they identified that their cell appears to be operating correctly (which with the clear casing I can visually verify), but communicating with the AquaRite panel incorrectly. They have seen this happen "very rarely", and to their credit, they are sending a new cell. I'll keep you updated as to whether this works.
    May 2009
    Aliso Viejo, CA
    2
    Quote Originally Posted by chiefwej
    Where did you get your T-15 cell? Did you go with the 1-year or 3-year warranty? Thanks.
    14K gal, AG vinyl (24' round x 52"), 1 HP pump, sand filter
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Quote Originally Posted by agenterf
    My original cell lasted over six years, so I decided it was worth it to pop for the genuine cell with three year warranty. I did some searching online and it didn't seem that there was a lot of price variance. I ended up buying one through Amazon for a bit under $500. But what the heck, $500 divided by six years is $83 per year for chlorine. Well to be fair I would have to allow a bit extra for the electricity to run it.....but still a good deal.
    chiefwej
