Thread: CYA-Is there a quicker way
    Glock30's Avatar
    Apr 2012
    Massachusetts, USA
    90
    Is there a quicker way to dissolve CYA into the water?
    I am currently trying the 'sock' in each skimmer basket method.
    I need to add like 13 lbs and I think this may take until fall.
    Thanks
    18' X 36' Inground Pool 26,000 gallons. SuperMax 27mil/27mil Vinyl Liner-Installed Fall 2011
    Pentair Intellipro Programable Pump (Model 011018) // Pentair S8M 500 Cartridge Filter // Circupool RJ45 Salt Chlorinator
    2 Hayward Skimmers // 3 Returns // 2 Savi Melody Pool lights // TF-100 Test Kit.
    38,251
    Re: CYA-Is there a quicker way
    Are you leaving your pump on 24/7? If not it may not be good to leave it sitting in the Skimmer. The other option is hanging the socks in front of the returns.
    In either case, you cab give the socks a squeeze every time you walk by to help it dissolve out of the sock.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    Leaving it in the skimmer is fine, it isn't that acidic.
    In the skimmer it should be gone from the sock in one to three days.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    I just dump it right in the skimmer (slowly) and let it get caught in the filter. If you dump too fast it can choke up the pump, but it won't take til fall this way Just make sure you don't need to clean your filter for the next week or so.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Just remember to trust the amount you have added, it can take a week or more for it to show up on the tests.
