Thread: Still can't decide...SWG or just BBB
    May 2012
    Northern Connecticut
    103
    I have read everything twice but I just want a simple answer...I'm going to be a new pool owner who is not great at maintenance (my deck hasn't been sealed in years ). We are putting in a liner steel walled pool. We have five kids. Should be go with a SWG or just BBB. If we go with just BBB, Do we need a special machine thing?
    Lastly, can we add a SWG later?
    Thanks
    Sandy
    24,000 20x42 double roman end in ground pool being built. Start date june13, 2012.
    Finished July 4th, 2012, sports pool, vinyl,SWG, DE filter, fountains. Heat pump,
    First Pool Ever!
    WestSidePool's Avatar
    Cincinnati, OH
    424
    Re: Still can't decide...SWG or just BBB
    Hi Sandy, to start off BBB is the process used to maintain a pool. This requires a person to take their pool into their own hands. You need a good test kit, to test your water, and then add chemicals accordingly.
    The SWCG (Salt water chlorine generator) is a machine that automatically produces chlorine only after you add salt to bring your pool up to 3500ppm.
    So the question, do you want to go to the store to buy bleach or chlorine and add it on a daily basis. Or would you prefer to use a machine that automatically chlorinates the pool and you have to check and maintain the numbers in my pool?
    If you read Pool School (upper right corner of the site) you'll get a better understanding.
    If you go with bleach/chlorine it's not necessary to have an additional machine, although there are a few offered.
    You can always add a SWCG later if you so choose.
    Eric
    IG 17x33 Grecian - Vinyl Liner (21k gallons), Hayward Pro-Grid DE 4820 filter, Hayward Super Pump, CompuPool SWG CPSC36, TF-100 Test Kit
    May 2011
    Clearwater, FL.
    446
    Hi Sandy and welcome to TFP!
    If you don't have a lot of experience with pools, start with BBB and you'll get a handle on how pool water chemistry works.
    Adding a SWG will not be hard to do and will be easier to setup because you will then understand water chemistry using them.
    Principles all the same just different levels to maintain.
    If you do enough reading here you realize you do need a good test kit to make this a simple task in the long haul.
    The TF-100 kit is the best value.
    See here:
    pool-school/pool_test_kit_comparison
    Chuck
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Do yourself a favor up front and allow for an extra foot or so of pipe out of the filter to make it easier to add a SWCG later if you choose. Wish I'd have known that then!
    Since you are a self diagnosed poor maintenance person (no judgement - I get it ) I would do the SWG. This will ensure that chlorine goes into the pool each day, and will not need your daily intervention once you get the hang of how to set it. Just my opinion...
    17'x36' Freeform (Omni/Gemini shape) Polymer Vinyl Liner Pool; Made by Hydra Pools; 6' Water Depth; Cantilever Concrete Stamped Coping; 8' Radius White Step; 8' White Cozy Cove with 6 Jets; 1.5 HP Pentair Whisperflow 2-Speed Pump; Pentair Clean and Clear Plus 420 Cartridge Filter; Kreepy Krauly Legend Pool Sweep; 2 Skimmers; 4 Returns; 2" Rigid PVC; Pentair 5G LED Light; Pacific Ultra Mesh Safety Cover; Pentair Intellichlor IC 40; 3 Deck Jets
    Welcome Sandy!
    I do both! Like was said earlier, the SWG just adds an easy way to maintain. The shock process using bleach saves on cell life and you have fast and complete control of the pool. Once the pool is where you want it (just days), the SWG make it so EASY to keep in in the proper balance. I love the acronyms.....should add KISS as it's that easy.
    Hope this helps....listen to the pros here and you will not be disappointed!!!
    16,000 IG, SWG, 175 sq. ft. cartridge, 1.5 hp pump, vinyl, Charlotte NC
    TF-100, Pool School, Pool-Calc
