Thread: Jandy Valve Sizing
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Jandy Valve Sizing
    When looking at Jandy valves there are 2 sizes listed 1.5/2 2/2.5, I assume the PVC can either go inside the valve or outside, correct? Is there a better way, inside or out? Or is this just to narrow down the sizes for more of a universal design for Jandy to produce fewer valve sizes instead of 4 sizes make 2?
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    38,548
    Re: Jandy Valve Sizing
    The smaller number is the size pipe that will slide into the valve. The larger number is the size pipe that matches the valve pipe size and requires a coupler.
    I do not think is is normal to slip the pipe on the outside of the valve. Otherwise you can imagine there would be a quick reduction in pipe size for the flow.
    So if you want fewer connections and not have to buy couplers, get the size where your pipe will slide into the valve. The internals are the same and the head loss is basically the same regardless of the pipe size you use with the valve.
    Herndon, Va
    65
    What if you are replacing the valve and need to use 90deg fittings at the valve? Would a 1.5" Elbow fit into the valve opening of a 1.5" valve or would it require a different size? It would be easiest if I could use the elbows in the fashion as then it would line up with the two return pipes I'm mounting this on.
    ____________________________________________________________ _____
    IG 25,000 gallon concrete painted pool,
    KDI American Products Model# 583090 Titan SS Vertical Grid 48sq ft DE filter
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    Elbows are designed so that the pipe slips into them, so use pipe between the elbow and the valve. My equipment pad uses some elbows near the valves and there are pics in my pool thread, link in sig.
    38,548
    You can get street elbows that would slip directly into the valves if needed.
