Thread: Reagent Replacement Question: R-0871 VS R-0002
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Up here north of the border we don't have a lot of choice when buying test kits and reagents, I need to buy some more R-0871 but the site in question only lists that in a quantity quite larger (and more expensive than I need).
    They also sell the following - which to my laymens eye appear to the be the same, can someone confirm if these are all interchangeable please:
    R-0002-A, DPD 2 22ml
    R-0002-C, DPD 2, 60 ml
    ok, so A and C are clearly the same, just different sizes, but can I use R-0002-A instead of R-0871-C, FAS? They only sell this in 60ml and that's that's way more than I need.
    Thanks
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Re: Reagent Replacement Question: R-0871 VS R-0002
    Nope, just found out elsewhere on the forum that they are not the same thing.
    Actually, for Canadians the reagent prices at http://piscines-apollo.com look pretty good.
