Results 1 to 14 of 14
Thread: What order should I do this?
    Okay, used my Taylor K-2006, results:
    Alkalinity 90
    pH 7.5
    CYA no reading available (can only read >30 on test)
    So I thought my chemicals were bad on the CYA, brought a sample of water to pool store and here are the results:
    CYA 10
    Alkalinity 92
    Hardness 113
    Optimizer 9
    So I need to raise my CYA (last season it was 90 so I'm glad it's down) and Borates but I think my other numbers are in line right? Is there any particular order I should do this? Any suggestions are appreciated.
    Thanks
    16x32; 15,200 gallon IG Vinyl, sand filter
    Feb 2012
    Phoenix, AZ
    728
    Re: What order should I do this?
    Yes, you should get CYA up to 30-50. The pool calculator will tell you how much to add. Liquid CYA (sometimes called stabilizer), will mix with you water much faster than granular..and will show up on your test sooner.
    Another thing..you did not list your FC. You will certainly want to measure that and make sure you are at the appropriate level for your CYA.
    TA (Alkalinity) and CH (hardness) are fine for your pool.
    Butterfly's Avatar
    South Carolina
    10,045
    What is the FC and CC and how does the water look?
    Welcome to the forum
    You're done SLAMing when:
    water is clear but FC is .4, I'll add a few gallons of bleach and it will be gone by the end of the next day due to low CYA. I've done the overnight test and things look good there.
    Oh, I already purchased the granular CYA. I need about 5 lbs so I can't do the sock trick, any suggestions?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by shawnf415
    Welcome to tfp, shawnf415
    Can you please put your pool details in your signature? It helps us help you!
    Why can't you do the sock trick?
    Sorry, I have a signature line. Just added dimensions, is there anything else I should have?
    30,427
    Your single most important job on your pool this summer is to keep adequate chlorine in it. EVERTHING else takes a back seat until you can get your chlorine usage evened out. Do not let your pool run out of chlorine.
    1. Put enough CYA in the pool to get to 50pp.
    2. Put enough chlorine in your pool to get to 6ppm.
    3. Keep testing and adding chlorine until you can keep it in your pool. You should only lose 2-4ppm daily.
    Once you have the chlorine consumption and additions clearly under control, you can begin to work on your other parameters.
    Thanks Dave, I'm headed outside (in the dark) now to address 1 & 2.
    Shawnf - I added 5# stabilzer today. I used 2 socks in front of 2 different returns (2.5# in each) but it worked great. The socks were empty in about 5 hours.
    30000 gallon inground gunite pool
    Intelliflo ic-60 SWG, pentair tagelus sand filter, 1.5 hp whisperflo pump, tf 100 test kit,
    2 kids(tl), 1 mini-dachshund/lab mix(t),
    Central Illinois
    I'll be honest, I'm a lazy pool owner. I dumped it in the skimmer basket. I also tend to dump my bleach as I walk around the pool I just don't have the ability to slowly pour it in front of the jet, when I try I'm usually done within 15 seconds which is much faster than the recommended 1 minute.
    30,427
    you would be better served putting it in front of a return......I don't think a one minute pouring time is necessary but we use that to emphasize it is important (with any chemistry addition) not to dump them in at your convenience because they need to be diluted. I put clorox in front of the return as fast as the jug will empty....that's probably not one minute but I still get INSTANT dilution and mixing and probably a better method that distributing around the sides.
    CYA in the skimmer is fine......just don't backwash for about a week.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Agreed, don't add bleach to the skimmer man, add in front of the return.
    I will heed your advice, thanks guys.
