Thread: Winterizing plug sizes
    38,262
    To all you winterizing types:
    Shockingly in May in Tucson, AZ pool stores do not seem to have winterizing plugs in stock
    So, I need to order a couple to allow me to replumb my pad.
    I need 1 for my skimmer to pad line and 1 for a return eyeball that is flush with the wall (and I have to figure out how to get the ball out first).
    I think the return is a little less than 2" diameter and I am not sure what the diameter is in the skimmer (probably pretty standard).
    Can anyone tell me which sizes of the winterizing plugs HERE I need?
    Or is there something else I could find locally to temporarily plug the 2 places?
    Thanks.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Winterizing plug sizes
    You should be able to get the rubber test plugs at Lowes or a similar store.
    38,262
    Are those the non-tightening ones that just press in? For my purposes that actually could be enough.
    bibeaud's Avatar
    Aug 2011
    P'Burg NJ
    73
    I use size 10 for my returns and size 12 for the skimmer.
    11,000 Gal Trilogy "Utopia" Fiberglass Pool, 1HP Jandy Pump, Jandy CS200 Cartridge Filter, Raypak 199k BTU Heater, Liquidator, CMP Off-Line Chlorinator. Cleaners: Polaris 360, Blue Diamond, Poolvernuegen Pressure
