Results 1 to 16 of 16
Thread: pool liner problems
    pool liner problems
    We just had a vinyl pool installed. The liner goes over the steps and the corners are a 2 foot reverse radius. The liner at the step end is not fitting tight against the corner or at the edge by the steps. The pool installer told me it just needs time to adjust. Any thoughts?
    27' AG, sand filter, 1.5hp pump, hard plumbed
    22,549
    Re: pool liner problems
    Welcome to TFP.
    What is the temperature there?
    It should fit pretty close but a good warm day will allow it to stretch out some.
    The temperature is around 85 but when I say it doesn't fit I mean it is buckling. It does this all across the top step into the reverse radius corner. When standing and looking at the edge you can see a ripple appearance.
    22,549
    It should not be wrinkled. If anything it should be tight. I'd make sure they fixed it.
    How do you suggest that would be done? I wish I had a way to send you pictures of what it looks like.
    22,549
    The Just let them know you're not happy and it needs to be fixed.
    That's the reason I am putting out questions,because they are trying to tell me this is how all liner pools look. I am questioning other people with liner pools to see if this is indeed the case.
    22,549
    Look at some of the other liner pools here on the forum and you'll see how smooth they should be.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    We need to see a picture of what you are describing before we can tell if what you are seeing is going to be ok or not. If you don't have a digital camera, try to borrow one and take a few pictures of the problem area. You can use a photo hosting site such as photobucket to upload the photo and then post the link in this forum.
    Love TFP? Become a
    TFP Supporter!
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    I had a lot of concerns during the liner installation process. I watched them set it all up only to take it down and shift it one way or the other a few inches. Every few mins. the crew leader was on the phone with the PB getting advice/instruction (in Spanish, which I can understand). The crew leader was suggesting the liner was a few inches too long....when they decided it was good enough and started putting water in it I voiced my concerns, and asked about the length (in English). The steps at this point had wrinkles and folds in the corners....eventually they got them worked out, they also used my heater to get the water up to 85, and now that the water is 90 all the wrinkles are gone either by water weight, pushing them out, or liner "settling in". PB also decided to raise my permanent water level to 1/2 inch below top of skimmer inlet, presumably to get more water of the top step (he didn't say). I'm happy. These pic are at night with lights on, you can see everything under these circumstances.....good and bad....
    Good
    Bad
    During fill up
    Sorry don't have picture of the "folds" that were there, I guess i didn't want to take a picture of them, but they all went away.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    The 2 foot radius corner, with wrinkle issues in the liner.[attachment=0:h89x0ty4]IMG_2898.jpg[/attachment:h89x0ty4]
    22,549
    Can you back off and take another pic so we can get a wider view?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Oh, so it's too big and not too small? Can we see a wider view? I'm still having a hard time picturing your reverse radius...
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    The pool is not yet full of water? How many "stages" are they having you fill it in? Are they adjusting it as it fills?
    18'x43' Sport Pool
    the original pictures i sent are no longer valid as they drained the pool and readjusted the liner on 5/7.unfortunately i am not 100% happy with these results either. the corners don't appear to be tight enough.do you all think with time they will tighten? I will say the air temp since 5/7 has not been greater than mid 70s so the new water would be even colder. i will send pics later but my daughter did other and i don't know how to attach till she gets home from school. thanks for all help
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Any updates?
    Here are some pics of what mine looks like, sorry for the quality they are underwater and at night....
    18'x43' Sport Pool
