Results 1 to 8 of 8
Thread: intermatic timer stopped working
    Apr 2011
    Houston, TX, USA
    105
    hey guys,
    out of the blue my intermatic timer stopped working. I believe i can still hear that clicking noise on the device, but the clock dial will not move no matter what i do. I pulled it, adjusted the time again, and pushed it back, and it is still not rotating the timer dial.
    any ideas on how i can fix it? i am generally handy.
    btw, switching the pool pump manually works just fine.
    thanks in advance.
    14500 gallon plaster pool (replastered in May 2009) : 32ft.L x 4ft.D x 14ft.W
    Pentair FNS Plus 48 sqft DE filter
    Polaris 280 at 2hrs per day (retired now) & Aquabot T-Jet Turbo used as needed
    Circupool RJ30 SWG set at 80% output & Pentair SuperFlo 1hp 2speed running 6-8 hrs/day in the summer
    38,284
    Re: intermatic timer stopped working
    Pretty sure you can replace just the timer mechanism.
    Apr 2011
    Houston, TX, USA
    105
    thanks Jason. i read that in another thread here as well. i called Leslies and they have this for $70. i was hoping there might be something else i could fix instead.
    Firemike's Avatar
    May 2009
    SE Michigan (Metro Detroit)
    8
    Most Intermatics you can buy just the timer motor. Also, most of the timers have a viewing hole in the baseplate where you can see the timer gears turning, if theya re not turning you need a new motor. Might try Graingers or any local electrical supply house. Shut the power off and take the old timer motor with you.
    Michael
    15'x30' AGP - 13.200 gallons
    2Hp 2 speed Pump - 93sf Cartridge Filter
    TF-100 Test Kit - BBB Method
    May 2008
    NE Florida
    51
    I did mine last year, I got the motor at Grainger for about $15 or less, very simple if you are handy. Though, make sure you pull the breaker.
    22K gallon free form pebble tec pool, non screened, surrounded by 3, 100+ year old Live Oaks (pure misery for 3 months every spring) elevated non heated spa, jandy cl340 filter, Pentair Inteliflo 3hp pump, Jandy 1400 swg, infloor cleaning system which has had all outlets removed due to uselessness of system with the organic load the pool carries and now low rp
    May 2011
    Orange County, CA
    696
    If you are still hearing the motor running, it might be stripped gears. Here's a slightly cheaper option:
    http://www.amazon.com/INTERMATIC-T103M- ... 01&sr=8-29
    Even cheaper is this electronic version, with 8 run cycles possible:
    http://www.amazon.com/Intermatic-PB314E ... 799&sr=8-3
    If it were me, I'd probably go with the second version... no more concern about moving parts, and this probably uses less electricity.
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
    Apr 2011
    Houston, TX, USA
    105
    thanks guys! these are great options. i will try graingers as they are near me!
    Apr 2011
    Houston, TX, USA
    105
    the little gears are not running. i guess i need a new motor.
