Results 1 to 9 of 9
Thread: Need advice about equipment in pool quote
    Apr 2012
    Prince George, VA
    33
    The pool will be a in ground fiberglass: 37' 9" L X 14' 1" W, depth 3' 10" - 6" 6"=20K gallons
    PUMP: Jandy FHPM 1.0-2SPD
    FILTER: Jandy CS 150sq ft
    3 Returns-looped off of 2" rigid PVC
    1 Skimmer straight run of 2" rigid PVC
    2 Main drains straight run of 2" rigid PVC
    SWCG: Zodiac APURE35
    Anything I should change? The builder only deals in Jandy equipment but was open to any "changes" I want to make!
    I was going to go with a sand filter because it's what my parents had in their pool years ago, but after he explained the benefits of a cartridge filter, I was OK with it.
    Thanks for any advice y'all can give me,
    Bill
    Barrier Reef Pacific1-Pacific color 37'9" X 14'1" fiberglass IG ~ 17,500 gallons, FHPM1.0-2 Jandy FloPro pump, Jandy Aquapure 1400 SWG, Waterco Multicyclone 16 pre filter, Jandy CV580 filter, 3 PAL-2000 RU LED lights, 1 skimmer, 2 main drains, 3 returns, 2" rigid pvc suction and return plumbing, BBB method, TF100 Kit
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Need advice about equipment in pool quote
    Jandy makes fine equipment, and I considered buying that same pump! I'd try and get a bigger filter; we always recommend the biggest you can afford and will fit on your equipment pad. It just means you have to clean it less often. You didn't specificially say it, but make sure the drain is not plumbed through the skimmer, but run separately to the pad. I'm a fan of individually run returns too, but looped works just fine. I would rather have them individually so that if one starts to leak, you can just shut it off and use the others.
    22,544
    I'd go with a larger filter, at least a 200 sqft. I'd also run all the returns back to the pad individually but that's not a must have, it's just a nice to have. Other than that, everything looks ok.
    Apr 2012
    Prince George, VA
    33
    Quote Originally Posted by Melt In The Sun
    You didn't specifically say it, but make sure the drain is not plumbed through the skimmer, but run separately to the pad. I'm a fan of individually run returns too, but looped works just fine. I would rather have them individually so that if one starts to leak, you can just shut it off and use the others.
    The main drain and skimmer runs are separate and 2". I will see how much extra the individual return runs are (if he will let me, I can do those). What diameter PVC should be used for 3 individual runs?
    Thanks for all of your and Dave's help!!
    Bill
    Isaac-1's Avatar
    SW Louisiana
    6,711
    One more thing, when they plumb your pad make sure they leave plenty of extra room and use couplers, so when it comes time to change out the filter, pump, etc. you don't have to cut out and replace all the plumbing. It seems pool builders love to set up the pad as tight as possible with no room to cut and insert splices if needed, it is far better to have a couple of feet of lead in on all the pipes and the fittings all snug up against one another.
    Ike
    22,544
    And use unions everywhere!
    Apr 2012
    Prince George, VA
    33
    Thanks for the help. Which of the following Jandy filters would you recommend: CV340, CV 460 or the CV 580? I will buy the CV580 since it's the largest unless y'all tell me differently.
    Thanks again for all the help,
    Bill
    22,544
    The 580 is a good choice.
    Best advice I tell everybody is use the biggest filter you can afford.
    DO NOT USE less than 2" plumbing. No matter how small the pool is you must use 2" or bigger plumbing.
    Leave room for add-ons to your equipment pad. Heater or heat pump, salt chlorinator, sense and dispense unit for chemical automation.
    Put in a color LED light. Do not use a white incadescent light. A color light like the Hayward Colorlogic LED light will make your pool look like a resort in your backyard at night. You will thank me later. Have fun with your new pool.
