Thread: Pouring deck - Access to returns
    Aug 2007
    Powhatan VA
    50
    I am preparing to pour the deck and I would like to install these over the returns :
    (not my buddy's hairy legs, the bright white thing)
    Both pool stores here are out of them, and I need them asap. I have tried searching but I'm not sure what they are called. I have been searching on 'return niche', etc. and the closest I can get is skimmer throat extenders. Do they have a name, and can they be bought online ?
    Thanks for the help.
    20x40 IG Vinyl
    33k Gallons
    Triton TR-100 Sand Filter
    Pentair WFDS-6
    30,432
    Over the returns? or over the skimmers?
    Aug 2007
    Powhatan VA
    50
    Hi Dave -
    The pool company that I bought the kit from (Medallion) installs these over the returns so they can be accessed from the rear and front. I just don't know what they are called when they are used for returns. The skimmer already has this assembly on top.
    Thanks ...
    20x40 IG Vinyl
    33k Gallons
    Pentair WFDS-6
    Aug 2007
    Powhatan VA
    50
    Hi Dave -
    Thanks ...
    20x40 IG Vinyl
    33k Gallons
    Pentair WFDS-6
    30,432
    That's interesting. Initially, it seems a good idea but, the more I think about it, I'm not sure I can think of an advantage.
    Obviously, it's to make any repairs that might be necessary but, if the return is 12"or so below the waterline, that would seem to make the lid about 20" above the return......virtually impossible to get down into to work on the back of that return.
    Does the manufacturer give reasons for them that make good sense?
    PS - Where I'm going with this is that you might consider skipping them....I'm not sure I've seen them on any pools....they certainly are not on mine.
    Dec 2007
    Central New York
    504
    Above each skimmer and return line, I have a concrete knock-out that can be hammered out if the line has to be replaced.
    Never seen those in the picture.
    You said both pool stores here are out of them, call them back and find out the name and who makes them.
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
