Results 1 to 15 of 15
Thread: Any idea what this pipe is for??
    Jul 2011
    Dallas, TX
    33
    I cant figure out what this pvc pipe is coming out of the ground. Any ideas?? thanks!
    Pool newbie. 25k gallon in-ground plaster pool with DE filter. MX8 and PoolSkim
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Any idea what this pipe is for??
    How about a wider shot for some context
    SW Georgia
    300
    Does it provide air for Jacuzzi jets?
    35K IG Vinyl 20 x 40 self built pool, Hayward Pro Series High-Rate Sand Filter 31" 98gal/min, Hayward TriStar 1.85hp, Hayward 400btu heater, BBB method w/Hypo, Jazz light w/matching fiber optic rope lighting around coping w/syncronized color wheels. Concrete Paver deck.
    Jul 2011
    Dallas, TX
    33
    No jacuzzi, I just have a pool. Is this maybe where I can pump water into the sewer if I have to drain? These are the only two pics I have as I am at work currently. It is also located near a pipe that goes underground when I backwash. Its the strangest mystery to me!
    My CYA is around 150 currently so this weekend I have to rent a pump and drain over half my pool. I was trying to figure out where I am supposed to pump the water.
    No more chlorine pucks for me! I got rid of my pool service, ordered a test kit and going to spend a few days on this site reading the right way to care for the pool.
    Thanks!
    May 2011
    Orange County, CA
    696
    It could be for backflushing a DE filter. It may also be a ground water relief pipe to prevent ground water from floating your pool when you drain the water. If the latter, I believe these are used to pump out the ground water around the pool so that it reduces the chance of floating the shell. Before you empty your pool, you really should find out if this might be for mitigating the effects of ground water. You might check with the local building inspector to see if they have any documentation on this for your house (or if they have knowledge of ground water issues).
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
    SW Georgia
    300
    Quote Originally Posted by jhever
    Thanks!
    I don't have a jacuzzi either but I do have jacuzzi jets in my steps that bubble like a actual jacuzzi. These returns have to have an air source which is why I have a similar pipe sticking out of the ground similar to the one you have pictured. These returns have a venturi that draws air in from the vent pipe.
    Sep 2011
    Plant City, Florida
    38
    How close is it to the air handler for your AC? Looks like it could be the condensate return.
    Jul 2011
    Dallas, TX
    33
    It is along that same wall about 10 feet away
    SW Georgia
    300
    Could it be the over flow pipe that is connected to the side of the simmer. My simmers have a pvc fitting on the side that you could plumb to automatically drain your pool when the water got to high. It comes from the factory pluged so in order for it to work you have to cut the plug out and it is located on the inside back wall of the skimmer. If this pipe is above the height of the deck it probably is not a drain line.
    Jul 2011
    Dallas, TX
    33
    Hmm...Its the strangest thing because its not close to the pump or skimmer. Such a mystery!
    When draining a pool with a sub pump where do I pump the water to? I cant figure out where I am supposed to dump 13k gallons of water.
    Thanks!
    Jun 2011
    Long Beach, CA
    2,778
    It looks to be too small for a backwash line, those should be about 3 inches or so. Does it point towards the AC unit and is that area full of rock? It looks like there is a green border that surrounds the pipe and that leads me to believe that it could be for the AC condensation drain.
    To test if it is an air intake for jets of some sort, blow air into the line with a shop vac. If bubbles come out of your returns then you have your answer.
    Any signs of irrigation system, past or present?
    3/4 inch PVC is standard in irrigation systems.
    Kansas City, MO
    13500 gallon Foxx vinyl sport pool--inground (1988)
    Cristal-Flo sand filter
    Ray-Pak 406A digital
    1.5 HP single speed
    400 gallon Heldor inground spa, octagon
    Jul 2011
    Dallas, TX
    33
    It points away from the AC unit which is about 10 feet away and comes out of the soil (no rocks). The only things near it are my faucet and a backwash pipe that comes up and then back down from the ground. When I backwash I can hear water moving through the backwash pipe that why I call it that. Its just odd its not near my pump. I'll see if I can get more pics tonight. Thanks everyone!
    Jun 2011
    Long Beach, CA
    2,778
    Is the faucet in the pool plumbing? If so, this might be a drain line for water coming out of the faucet. It looks like the end is threaded and a hose with two female ends might attach to the faucet and this line. It is definitely not a backwash drain as it is not large enough for that volume of water, but it could handle water out of a faucet.
    I would dig down the line and see if it is running away from the pool to make sure it is not going to do something to your pool.
    Jul 2011
    Dallas, TX
    33
    Thats what I thought too and bought a female/female adapter for the hose but it didn't fit. I'll try digging to see if that helps figure out where its going. I even tracked down the old homeowner and asked if he had any idea what that was for and he said he had the same questions and never figured it out.
