Results 1 to 7 of 7
Thread: Pool care while on vacation ?
    What arrangements do people make for pool care when they go on vacation ?
    I am hoping to start maintaining my pool myself this year but I just realized I will be gone for a couple of weeks in the summer and I am not sure what to do. I'm sure our friends will be using the pool while we are gone, but can I'm not sure if I can trust them to take good care of the water. Will I be able to get away with them just lobbing in some chlorine a couple of times while I am gone ? Should I get a pool company to stop by ?
    15,000 gallons, IG, Plaster, Pentair 2000 DE Filter.
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    Re: Pool care while on vacation ?
    I've got an SWG. I go on vacation and when I come back it looks the same. The only thing I do is put the thermal cover on. So far it's worked. You always worry though. I do have an outside camera looking at the pool so I can keep an eye on it. I usually need to get about 16 oz. of muriatic acid in each week, so I would normally instruct the kids who take care of the dogs to put it in a measuring cup and put a cup in once every week.
    As long as your CYA is low, you can put pucks in your strainer baskets. They last about 3-4 days.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    Jun 2007
    New Jersey
    653
    I turn to pucks on my summer vacation. I run my CYA somewhat low to allow for my 2-week vacation. I have a Rainbow 320 that takes care of the first week. I ask a friend to drop by at the end of the first week and check the water level and throw in a pre-loaded floater with more pucks for the second week. If I ever went for three weeks, I'd just buy another floater. I don't cover and I have never had a problem.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by Durk
    Same here.
    When somebody comes to swim, I have them check the chlorine level and have a chart showing how much bleach to add depending on what they read. Before I had a timer, I had my son-in-law drop by on his way home from work to turn the pump on/off on alternating days.
    38,271
    Quote Originally Posted by Jimk
    If you are nice enough to let them use your pool while you are gone, the least they can do if do the basic pH and FC tests and add a little bleach / acid as required.
    Tell them if you come back to a problem, they are no longer welcome to the pool while you are gone
    Fair point !
    But does nobody worry about brushing and vacuuming the pool for a couple of weeks ?
    38,271
    The important thing is to keep adequate FC in the pool and the pH in range. A little dirt and leaves will not hurt anything if the FC is kept up.
