Results 1 to 11 of 11
Thread: Opening another pool, closed 2 years
    Nov 2010
    South Central Kentucky
    283
    I have a pool that is new to me for maintaining. It's at a rental property I own. I'm working on getting info from the builder on gallons and such, but the equipment is the same as what I have at my home (same builder).
    I'm going to start opening the pool today but I have an issue. I can't add water yet to get the water up to the skimmer because the builder is supposed to come fix some issues with the liner where it is pulled out from the bead locks in the corner. The builder said they would repair, so that's why I'm not doing it myself. They can't get to it for a few days so in the meantime, I'd like to start on the water cleanup process. The tough part is that the pool hasn't been opened in 2 years and it is covered, but with a mesh cover. I know it's going to take some time to clear. I'm planning to take the cover off tonight to assess the situation and scoop out any debris such as leaves that can't be cleaned through the filter. Pending the answer to my question below, I will see how much I can do in my current situation.
    Here's my main question. If I can not put water in yet to get up to the skimmer, or above the returns, can I still turn on the pump? I would think if I closed the valve to the skimmer (only one) and just opened the floor drain, this wouldn't be an issue. Would the returns being above the water line be an issue? The only risk I see is if something clogs the floor drain.
    15x32 vinyl liner, 14,400 gal, 1.4hp Centurion pump, 3/4 hp booster pump, Hayward Pro Series S244T Sand Filter, Hayward H200 heater (digital readout)
    Aqua Rite Electronic Chlorine Generator, Hayward Phantom cleaner, TF 100 test kit
    Pool School, Pool Calculator
    38,285
    Re: Running pump through floor drain only...
    If the skimmer and floor are plumbed to the pad separately, then closing the skimmer and only using the floor should not be a problem. Just make sure there is not too much junk on the bottom that could clog the floor drain and starve the pump (which you mentioned). I also do not see why the returns being above the water level would be a problem ... other than the aeration making the pH rise possibly.
    NJ
    291
    That should work, the only problem you might have is the valves to the skimmers may not seal perfectly and you may pull air. If that happens you should be able to screw in some plugs into the threaded hole in the bottom of the skimmers to seal them tightly and prevent air from being pulled in.
    20x40 IG vinyl, heatpump and solar and 3 siberian huskies, 10kw PV solar electric system. Nikon Photographer D800e dSLR.
    Nov 2010
    283
    Well, a couple things have happened since getting started on this pool.
    Took the cover off and things were a mess. Not as bad as I had anticipated, but bad enough. I could see the bottom, and it was covered with crud. As I started scooping up loads of worms with my net, visibility went to zero (and I still can't see the bottom). After I did what I could, scooping blindly, I decided it was good enough to crank up the pump. I figured out which valve went to which component and opened the floor drain, filled the pump basket with water, hit the switch and buzzzzz....nothing. Pump was dead. I called the pool guy I know and he said it was likely just siezed from sitting so long. So just to feel better about myself I poured in a 182 oz. bottle of bleach, brushed the pool and left. (Yeah I know i wasted a bottle of bleach, but it made me feel like I'd at least done something. )
    The next day, pump is running now off of the floor drain, and I'm ready to start again. I added some bleach to get the FC levels up based on what I was told the pool size was from the builder. Next was the vacuuming. Problem is, the water is below the skimmer. I'm not sure what the difference is, but the port in the bottom of the skimmer of this pool doesn't allow the vacuum hose to "wedge" in there to make a seal, it just sits on the ring at the bottom of the threads and doesn't really hold in place. On my first attempt after filling the hose from the return (trick I learned on here) I put the hose in the skimmer port and opened the skimmer valve. The seal wasn't good enough and I could tell it was starting to suck air so I closed the valve. On the second attempt, I took my water hose, and put it in the skimmer to help suppliment any leak by and tried again. This worked well. I vacuumed for a while, mostly in the blind, backwashing quite often. After I did what I thought I could do and I stopped getting drastic pressure changes I called it good enough for now. I added more bleach assuming it had been burned off, didn't test.
    Fast forward a couple of hours, since it's a rental house and I can't be there during the day or get my wife to assist at regular intervals, I tested the salt levels and added the salt for the SWG so I could use it to help me maintain my FC levels. I tested the FC. 28ppm, oops, too much bleach. I was calculating based on a full pool, which it currently isn't. Hopefully this won't cause any issues. I added CYA also to get the level to 30. The pool will be filled today. The SWG finally measured the added salt to a level high enough to get the generator going, so I cranked it up and left for the night. I'm going to have my wife go over and check the FC levels shortly and see where it's at. I'm not sure on how much FC the SWG can generate. That's where I'm at now.
    Here's a pic after removing the cover before any work was done.
    Nov 2010
    283
    Re: Opening another pool, closed 2 years
    Here's an update from Saturday on what the pool is looking like now. I think it would be clearing up faster if I had known that I should have initially vacuumed to waste instead of into the filter. I've been backwashing but I think I got quite a bit of gunk in the filter. It's getting better though. Pressure is about back to normal after several backwash/rinse cycles.
    Nov 2010
    283
    Here's the latest update on the pool after some more vacuuming and balancing levels. This was last night with the pool light on. Sorry for the crappy picture.
    Also, I have noticed that the pump has gotten quite loud over its normal level. Is there something I can check? If you'll remember, it was seized up when I first started the pool.
    Looks like you're on the right track. Regarding the pump, mine started making a loud noise when one of the bearings went out. If you catch that early it should be an easy repair for any electric motor shop (rebuild costs around $100 around here.) I wouldn't wait too long to get it checked or you could be looking at replacing a motor.
    16x32 Oval In-ground Vinyl, ~17,000 gallons, Hayward 1hp Superpump, Hayward S245T Sand Filter
    Worn out sand? sand-filter-expert-help-t30049.html
    Drain the easy way: cyanuric-acid-blues-draining-pool-t43843.html
    http://tftestkits.net/splash-page.html , pool-school/chlorine_cya_chart_shock , pool-school/shocking_your_pool
    Nov 2010
    283
    Here's the latest from yesterday afternoon. Pool is just about ready for the overnight drop test.
    The first picture is of some stains on the bottom, which I'm assuming happened when the pool sat for so long. Any ideas on getting them cleaned up or at least less noticable?
    Another discovery yesterday is that there's a leak somewhere around the level of just above the bottom of skimmer. In a days time, the water will leak down to that level and stop. I'm working on getting that remedied.
    The pool is looking great!
    Off topic but you were talking about pumps. Just to satisfy my curiosity how many years does the average pump last for, before needing to be replaced?
    1970's kidney shaped pool. 23,000 gallons with concrete bottom and fiberglass walls, both painted in 2012 with epoxy paint. Single speed "energy efficient" 1 hp hayward super pump and hayward S-200 sand filter. Main drain leaks, and is thus disconnected. 16 mil ultraclear solar cover. Located in Northern Indiana. TF-100 Test Kit
    Nov 2010
    283
    I'm not one to answer that. I think it really depends on the type of pump and if it is operated under the right conditions. I'm sure someone else will be able to chime in with a better answer.
    22,549
    Try to crush up some vitamin C tablets and put them in a sock and use your pole to hold it on the spot for a little while and see if that fades it.
