Thread: Return Jet Cracked--Can it be fixed from inside??
    Jul 2007
    Louisville
    21
    We had the leak detection service come out and the source of our leak is a cracked return jet. We were told it was caused from the groung settling. They want $1200 to fix it. They said they would have to bust up concrete to get to it from the back. My husband has it in his mind that this could be fixed without busting up concret and maybe using some kind of epoxy to fill the crack? Is it possible?
    c ya, grivera
    IG, Cement, 18,600 Gal; DE, SWCG, Nature 2; 1.5 hp pump; Quartz Aggregate, Mid-Atlantic-1st opened 7/07
    Feb 2012
    Phoenix, AZ
    728
    Re: Return Jet Cracked--Can it be fixed from inside??
    I am not sure if this can be fixed from the inside..but maybe someone else can help out. I did notice, however, that you posted the same question twice. I am pretty sure the mods will combine your posts..because you should stick to one thread. Hope you get the answers you are looking for!
    SW Georgia
    300
    If your pool returns are like mine they have to be accessed from behind the pool wall. I had cracks as well, due to settling, but because my deck was done in pavers I was able to just pull up the pavers necessary to get to the back of the return jet. I would try anything to avoid tearing up concrete. If it then does not work you could bite the bullet and have it done.
    35K IG Vinyl 20 x 40 self built pool, Hayward Pro Series High-Rate Sand Filter 31" 98gal/min, Hayward TriStar 1.85hp, Hayward 400btu heater, BBB method w/Hypo, Jazz light w/matching fiber optic rope lighting around coping w/syncronized color wheels. Concrete Paver deck.
