Results 1 to 9 of 9
Thread: Opened pool 2 days ago, frequent DE filter cloggin
    kevreh's Avatar
    Jun 2007
    Annandale, VA
    403
    I'm going to throw this out there even though I suspect I know what the problem is. During the first couple days after opening I've had to backwash my DE filter 3 times. The pressure goes from 12psi to about 20psi in 1/2 a day and the water flow slows down.
    Now, I think the problem is that its been a very mild spring that has lasted a month already. The water is darker with more algae than any year before. I think thats the issue.
    So, should I keep on backwashing? Or should I bypass the DE filter, and once the chlorine kicks in will it oxidize the algae? I was low on salt so my SWG just kicked in later yesterday.
    Kevin
    16x32 Concrete IG 24k Gallons
    Equipment: Carvin 525sf Cartridge Filter, Jandy Gas Heater, Vortex Solar Panels w/solar valve, 1hp Hayward Pump with 3/4 HP AO Smith 2 Speed Replacement Motor, Aquarite Saltwater Cell, Polaris 280 Dolphin Active 20 Robot
    Automation: Hayward Prologic Controller
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Opened pool 2 days ago, frequent DE filter cloggin
    What you are seeing is the "downside" of DE filters. They are too efficient when the water is dirty, and you need frequent backwashing. You may want to recirculate until the algae is dead, but at some point you'll need to filter to remove it from the water so it will take a lot of backwashing.
    Maybe filter while you are home and switch to recirculate before you leave to keep flow going.
    kevreh's Avatar
    Jun 2007
    Annandale, VA
    403
    Yeah, sort of my fault because I didn't shock before closing like I usually do. That with the very mild spring means my pool has been sitting there creating algae for the last month or so.
    Thanks for letting me know. Just checking.
    Sep 2007
    Tinley Park, Illinois
    74
    We are having the same problems. We opened the pool with ALOT of algae - more than we've ever had. This was the fourth winter that we haven't covered the pool for the winter. This was a weird winter and had some 80 degree days in March.
    We kept backwashing our DE filter, but we keep losing pressure. It doesn't help that our pressure gauge is broken. I will have to run out and purchase a new one. My husband took the DE filter apart today and cleaned it with the muracid acid treatment. When he put everything back together, the pressure was great. But then after 1.5 hours, the pressure died again. He bumped the filter and the pressure was okay. We know that it's not going to hold up.
    So, after reading the post here, do you suggest that we put a submergible pump into the pool when we are not home to keep the water sort of flowing? Both of us are gone for most of the day and we don't want the pump running when there is no pressure.
    Thanks for any help you can give me.
    24 ft. round Artesian above-ground pool
    54" depth
    15,000 gallons
    Hayward 1.5 HP EC45 DE Filter
    Hayward H150 Gas Heater
    SW Indiana
    9,199
    Just set the filter to recirculate while you are gone.
    Sep 2007
    74
    How do I set the filter to recirculate? I didn't think I can do that with my filter? Thanks.
    54" depth
    15,000 gallons
    kevreh's Avatar
    Jun 2007
    Annandale, VA
    403
    You should have a multiport valve that looks like this: http://www.poolcenter.com/images/valves ... emount.jpg.
    On top of it should be a position for Recirculate. Turn your pump off, turn the valve to Recirculate than turn it back on.
    I my case I just had to keep on backwashing. Probably did it 4 times over 2 days.You shouldn't have to take the DE filter out and clean it....not necessary.
    Aug 2010
    Maryland
    13
    Actually we did have to take out our filter and clean it after maybe 4 backwashes because we had so much algae we couldn't backwash well enough the fifth time to get the pressure to come down. I should mention that we started out with a clean filter prior to opening the pool but the amount of algae was just too much for it and it is doing fine now.
    30,000 gal 20x 40 inground vinyl, 3.5 to 8.5 ft deep, intellichlor SWG, pentair 48 sq ft vertical grid DE filter, 1 hp pentair pump+ booster pump for kreepy krawly pool vac, sun ledge, diving board, intellibrite LED pool light, tf100 test kit
    Apr 2010
    Central NJ
    227
    I had the same issue, so once the water got clear enough on the shallow end that I could see the bottom, I started to vacuum to waste instead of brushing. So far my filter is going on 5 hours without the pressure rising too much.
    23K gallon, IG, Vinyl, Hayward DE-3600 Filter, Raypak 406A Heater, Hayward 1.5HP SP2610X15 pump aka AO Smith UST1152, TF-100 Test Kit
