Thread: rust coming through gunite
    I've got a few spots of rust coming through the gunite shot on Monday. Is this normal or should I be concerned? We are planning on finishing with pebble sheen. I'm hoping that will seal the rust in where it won't be a threat. Thanks for you replies.
    La Porte In
    24' round AG odyssey trendsetter swimline
    15,292 gallons (ITHINK) (will confirm this after its not a swamp)
    zodiac pacer 1500 pool vac
    zodiac nature2 pro A plus AG sanitizer
    filter - voyager swimpro by hayward pool products
    Re: rust coming through gunite
    If the paster is applied correctly it won't be a problem. Occasionally a builder will use a paint like sealer in those areas before applying plaster, but that is rare.
    Whew, I feel better now. Thanks!
    La Porte In
    Mar 2011
    Houston, Texas
    413
    One of the PBs we interviewed (but he was too busy to give us a bid!!!) in 2010 made a point of saying that he uses a special stainless steel wire to connect the rebar so that rust like this couldn't happen if the plaster starts to wear down over time.
    9,200 gal. Gunite Luna Quartz French Grey pool with spill over spa, two fountains on tanning ledge (rarely used)
    Pentair Whisperflo 2HP, Pentair CCP Cartridge 420 Sq. Ft., Polaris 280 with booster pump
    Pentair EasyTouch 4, RayPak LoNox 266k Natural Gas heater, Aqua Rite SWCG T Cell 9, Borates, TF-100 test kit
