I have a circupool RJ45 which worked OK for a year, except blowing the internal fuses a few times, but now it will not generate chlorine, signals "no water" and has burned connections on the plug to the (new) element. It carbonized the rubber, but I cleaned it, and think it is getting a good connection, it shows almost 30 DCV at the 3 terminals of the plug, but the unit has quit producing chlorine, says "no Water" (but it has water and salt). I added salt and the strip says it is good. Any ideas? Pool is clear and has been perfect, until this problems. Answers? How do I get the unit to start clouding the water flow like it used to?
