Thread: NEWBIE - Low water level, gurgling, and no water in skimmers
    Pool was opened on Thursday. Everything has been working fine. Today I noticed that the water level in the pool had dropped, there is gurgling in the deep end and water is racing through the skimmers, but there is no water level in either of them. Ideas?
    I know this sounds simplistic, but my pool expertise does not extend to the mechanicals - just got pool chemistry figured out! Thanks.
    36K inground, Hayward 450SF Cartridge Filter, Hayward 2HP Pump, River Rok Granite Pebble Finish, soon to be SWG
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: NEWBIE - Low water level, gurgling, and no water in skim
    Shut that pump off! You need to have enough water in the pool that the skimmers don't empty because the pump will suck air.
    Mar 2009
    Huntsville, AL
    156
    After adding water you might also verify that the skimmers weirs are moving freely. They act as flaps and should open to let the water in and then float closed when the pump stops to keep debris from floating back into the pool. Sometime they stick and restrict the inflow of water.
    27K gal, IG vinyl, 1.5 HP pump, 24" sand filter, Goldline Aqua Plus SWG
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,112
    Often there will be an arrow on the skimmer somewhere. This shows what the water level should be. The pump will suck air and lose its prime if the level is far below this point. If the pumps runs dry for to long the gaskets will melt, and you will leak water.....worse case the motor will heat up to much and seize up.
    Shut off the pump till you can add water.
