Thread: when can I remove the shotcrete forms?
    Aug 2010
    Charleston, South Carolina
    77
    I'm hoping to have my pool shot next week. Half of it is inground and about 4' of it is above ground. How long should I wait before I remove the plywood forms. 1 day, 2 days, longer???? Also is there a certain amount of time I should let the shotcrete cure before I install the waterline tiles?
    half Inground/half above ground, shotcrete pool, 19,000 gallons - KrystalKrete Krystal Blue quartz finish
    Pentair intelliflo variable speed pump - Pentair Easy Touch automation - Pentair T100 sand filter - Savi Melody LED lights - Mortex KoolDeck - Charleston, South Carolina
    Feb 2012
    22
    Re: when can I remove the shotcrete forms?
    You can pull the forms - 1-2 days after it is shot - water cure compete form and pool side - I would do a complete 7 day water cure including the beam - then install tile - coping etc
    (Remember no rebound should be used in the structure)
    check video Swimming pool section
    Chris
    www.shotcrete.us
