Thread: Foam bottom
    Apr 2012
    Seymour ct.
    14
    Foam bottom
    Hey guys I had a 15x48 intex metal frame. It had 1inch of sand on the bottom the wasn't that smooth. The next door kids throw big rocks and bricks over the fence and split the liner. 4400 gal of water came rushing out in the street. The next door neighbor had to buy me a brand new one. So now I'm going with a foam board bottom. I have 1" 4x8 Extruded Polystyrene sheets from lowes to put down. I have a budget to work with. The 2" is to much for the budget. Duct tape then put a hd trap on top of the foam. Is that ok to put under the pool? Also can I put pavers/bricks under the legs or will it put a hole in the liner?
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    Re: Foam bottom
    Pavers/bricks are a must with the thinner foam board. Cut out the foam for the paver where the leg is.
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    Apr 2012
    Seymour ct.
    14
    Re: Foam bottom
    Thanks for the info. Won't the pavers dig threw the bottom of the liner tho? Like the edge of paver!!
    Re: Foam bottom
    only if it's touching the liner....the pavers go under the vertical pole feet, not under the liner.
