Thread: Alkalinity test question.
    Hello,
    I've been wondering if on the alkalinity test where it says add the titrant until it turns from green to red, if that means until its like a bright red or when it just doesn't look like green anymore.
    Thanks for many help, Whitehat
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: Alkalinity test question.
    You add drops until it stops changing colors. Then deduct one.
    For instance, say your TA is 100. At 8 drops it starts to turn grey. At 9, a tinge of pink, at 10 it's barbie pink. At 11, it's still barbie pink. The last drop did nothing, so 10 drops. TA= 100.
