Results 1 to 19 of 19
Thread: Opening Time?
    Aug 2011
    Selinsgrove, PA
    17
    Opening Time?
    Is anyone in the northeast and planning on opening their pool this week? I am in PA and it looks like the next few days are to be in the 80s so thought I would see what others in the area are doing...
    Shaun
    24K gal, vinyl, Hayward S244T sand filter, Dolphin Dynamic cleaning robot
    Circles47's Avatar
    Sep 2011
    Covington, Ohio
    42
    Re: Opening Time?
    Been tossing it around too, Shaun. I'm in Ohio, and it looks like the temps are going to be consistently higher for the next couple weeks. I actually opened mine several weeks ago, and had to do a partial drain to reduce my cya. It's now crystal clear and well balanced, and I'm wondering if it's time to turn on the heater. Last night the water temp was still 56 degrees!
    Sharkline 24' round AG, 15,200 gal, vinyl liner, Hayward Power Flo Matrix 1-1/2 hp pump, Hayward S210T 200 lb.sand filter, Rheem 100 cfh heater
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    Re: Opening Time?
    I'm in North Central Maryland and opened my pool yesterday, April 30. Waiting for the clouds to break to warm it up a bit.
    20x40 IG Vinyl, 1.5 HP Whisperflo, Sta-Rite System 3 (300) Sq. ft Cart
    Intellichlor IC40 SWCG, 125,000 BTU Pentair heatpump, Polaris 280
    7' IG FG Spa, 2 HP Whisperflo, Pentair Dynamic III Cart (100) Sq. ft
    Lehigh Valley, Pennsylvania
    71
    Re: Opening Time?
    I'm in the Lehigh Valley area of PA, up and running as of last week.
    25K gal vinyl inground, 1HP Hayward Pump, Hayward DE 4820 Filter
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,098
    Re: Opening Time?
    About 30 miles west of Pittsburgh here.....had the pool open for about 3 weeks now. Only a few feet have hit the water...but it's got the solar cover on it and is crystal clear ready for swimmers when the weather is.
    Sep 2009
    Frederick County, MD
    185
    Re: Opening Time?
    North Central MD here as well, and I opened on Sunday.
    Jim
    Southern Frederick County, MD - Leisure Moroccan 38 Fiberglass Pool - 19,800 gallons
    Pentair 1.5 hp 2 speed pump - Cartridge filter - Dolphin robot - TF-100 Test Kit - SWCG
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    Re: Opening Time?
    Opened over a month ago to avoid any green stuff here in North Central MD.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    Dec 2009
    Central Massachusetts
    2,690
    Re: Opening Time?
    I opened 2 weeks ago. Just waiting for warmer weather to turn on the heater.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Sep 2009
    185
    Re: Opening Time?
    Quote Originally Posted by XsAllOverIt
    Do you open yourself, or have someone do it for you? I opened myself for the first time. Water was clear, and shill had a decent amount of chlorine in it. The rest of the chems were off a little, and I will fix that tonight.
    Jim
    Dec 2010
    560
    Re: Opening Time?
    I open and close by myself. I had a falling out with my PB and I read a lot. Closing was a breeze and my pipes are under 6 feet of ground and come up in a pool house that hasn't yet gone below freezing, but I still do the standard closing. This past winter though wasn't a good test. It was very mild, but when I unplugged all my lines, they were obviously empty when all the water gushed back in them. Opening is a breeze - take the cover off and clean. I place my cleaner in my pool periodically during the winter to clean it to avoid too much of a mess by spring. My biggest issue is 5 maple trees within distance of the pool. The **** that comes off of them is UNBELIEVABLE and I got an estimate to get rid of all 5 for $15K. I can probably deal with 4 of them, but I'll have to pay someone for the 1 which is in range of my pool and poolhouse. Still picking up helicopters all OVER the place.
    TFT-100 test kit
    Jun 2007
    New Jersey
    653
    Re: Opening Time?
    NJ here. Just peeled a corner of cover and took temp and water sample. Water is nice and clean and no worms--I guess due to dry Spring. Temp is 51F and chems look good--FC still at 1.0. I'll open it up this weekend before it heats up enough to grow algae. I don't touch the pool all winter except for checking the cover pump.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    linda1's Avatar
    Mar 2010
    Western Pa.
    298
    Re: Opening Time?
    I'm 75 miles north of Pittsburgh. I opened and balanced the water in March when we were having unseasonably warm weather. Of course it then turned cold again, but we are ready when it does warm up.
    30 ft. round Conquest agp, 19,800 gal; Pentair Easy Clean 1 hp DE EC60 filter system
    Hayward H250N gas heater; TF100 Test Kit
    2 Fafco 4x20 sunsaver solar bear solar panels
    Dolphin E 10 ~ Zoomerang slide
    Majestic 8000 Above-Ground Pool Step
    Mar 2010
    Quakertown, PA
    50
    Re: Opening Time?
    Upper Bucks County, PA, here, opened a couple of weeks ago. Would rather have the rain in the pool than on the cover. Ended up with a lot of debris from the cover in the water, but, cleaning, etc. and it's getting there. Water is 58 to 60. For some reason, CYA and -B4O7 disappear over winter, so, I have to add it in again.
    Arvil, 30ft round, 21k gal, AG/vinyl(2003), StaRiteIII hp cartridge 150ft, Polaris65.
    6/30, Temp83F (28.3C), pH 7.8, FC 2.8 ppm, CC 0 ppm, TA 100, CH 80, CYA 40, -B4O7 30, CSI-0.17.
    Jul 2011
    Eastern Ohio
    7,098
    Re: Opening Time?
    well.......guess it's good to be young. My 5 year old got in for about an hour today.
    Aug 2011
    Selinsgrove, PA
    17
    Re: Opening Time?
    Thanks everyone. Opened it Monday night and found out the closers (last time I think I pay someone) didn't get all the water out of a section of pipe because had some major cracking. Fixed that and turned the pump on yesterday afternoon. I know you all like pics, so here is the transformation from day 1 to day 2 (20 hour interval) with $40 of bleach. And yes, I realize the opening is VERY ugly. Again, last time I probably pay someone to close the pool...
    [attachment=1:qx7dn14o]Before.jpg[/attachment:qx7dn14o]
    [attachment=0:qx7dn14o]After.jpg[/attachment:qx7dn14o]
    Firemike's Avatar
    May 2009
    SE Michigan (Metro Detroit)
    8
    Re: Opening Time?
    Metro Detroit here.... Thought about opening it today (May 3rd) but they are predicting scattered storms for the next few days, and all the whirlybirds from the maple trees are still flying around. As much as I hate to I should wait for a few days... Just ordered refill chemicals from TFTestkits.com so it won't hurt to wait.
    BTW... Wife actually wanted me to open in back in March when it was in the 80's.... ???
    Michael
    15'x30' AGP - 13.200 gallons
    2Hp 2 speed Pump - 93sf Cartridge Filter
    TF-100 Test Kit - BBB Method
    Circles47's Avatar
    Sep 2011
    Covington, Ohio
    42
    Re: Opening Time?
    Here in Ohio, we're anticipating a warm week and weekend, so I turned the heater on yesterday morning. The water temp is now 87 degrees, and we've been swimming for several hours. I know it's going to cool back down, but at least we can enjoy it for several days! [attachment=0:3kbv3u0r]0503121516.jpg[/attachment:3kbv3u0r]
    Re: Opening Time?
    Opening this weekend here in Pittsburgh PA!
    Southeast Georgia
    IG 27,000 gallons w/ flow over spa
    Diamond Brite
    74 gpm Sand Filter
    2HP Pump
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Opening Time?
    Illinois, just south of the WI border, and I'm on the 10 day countdown til opening.
