Results 1 to 10 of 10
Thread: wondering how long I can use pucks for
    Nov 2011
    Pasadena, California
    16
    Hello all,
    My mom recently had her pool re-done last December. It was built in the late 50's, and was last replastered in the 80'2. We had all new plumbing, drains, skimmer, and added a few more returns. The pool looks great, previously my parents had a pool guy doing the maintenance, and that pool went for 25 years with pucks and never was drained. I never tested the water, but it always looked good.
    Since the remodel, I started to do the maintenance myself, but I live about 5 miles away, and sometimes only make it over there 2 or 3 times a week. My plan is to use trichlor pucks for a while, and bleach to shock if/when needed.
    My tests results:
    pH 7.8
    chlorine 3 ppm
    alk 100ppm
    carbonate hardness 200ppm
    CYA <30 but >20ppm
    My reason for wanting to use the trichlor for a while is because we had quite a bit left over from prior to the remodel, my CYA is still pretty low, and I cant get over there every other day consistently to add bleach.
    So my questions are, how long can I use the trichlor for, and when I switch to bleach is every 2 to tree days feasible to keep up with demand? My mom is 80, and I don't want her to have to mess with it.
    I currently keep 4 pucks in the floater, and need to add about 2 a week to keep it topped off.
    Pool is crystal clear so far, thanks for the advice!
    30,000 gunnite with emerald bay pebble tec
    Pentair fns 60 square feet DE filter
    Whisperflow 0.75 hp pump
    22,549
    Re: wondering how long I can use pucks for
    You can use the Pool Calc to figure out how many you can use before the CYA gets too high. Take that, the starting CYA and the fact that you use 2 tablets a week and you can figure about how long you can use it.
    38,290
    What is your mom's pool volume? (assuming it is not the one in your signature)
    You can use poolcalculator.com to see the affects of adding various chemicals at the bottom. For example, if the pool is 30,000 gallons, every 7 oz trichlor puck adds 1.6ppm FC, 1ppm CYA, 1.3ppm salt, and lowers pH by 0.09
    Nov 2011
    16
    The pool is 30,000 ....are the large pucks 7 oz each?
    Thanks, I did not notice that part of the calculator.
    38,290
    The 3" pucks are roughly 7oz each.
    22,549
    They make different sizes of tablets, so you'll have to look and see which size you have. 7 oz and 8 oz are common sizes.
    38,290
    Ah good to know. I thought I remember them being 8 oz and then a quick search revealed 7 oz ... did not realize it could be both.
    Nov 2011
    16
    Ill go check the tub when I get up there. Now, I realize that it is highly variable, and dependent on a variety of environmental factors, but in general, does a pool with adequate CYA and a low bather load require daily additions of bleach to keep levels on target?
    38,290
    Well, you will always be loosing FC to the sun even with the CYA. Seems like many pools use 2-3ppm of FC a day. After some measurements, you should be able to figure out what that pool uses. You could then add FC for 2-3 times that use and then only have to add more every 2-3 days.
    Nov 2011
    16
    Leslies 3" tabs are 8oz of trichlor. Thanks you all for your help.
