Thread: Intelliflo 011018 Pump-Programming Help Needed
    Glock30's Avatar
    Apr 2012
    Massachusetts, USA
    90
    Anyone out there have any reccomendations on how to setup (program) these pumps for energy efficiency and functionality?
    Specs in signature.
    Thanks
    18' X 36' Inground Pool 26,000 gallons. SuperMax 27mil/27mil Vinyl Liner-Installed Fall 2011
    Pentair Intellipro Programable Pump (Model 011018) // Pentair S8M 500 Cartridge Filter // Circupool RJ45 Salt Chlorinator
    2 Hayward Skimmers // 3 Returns // 2 Savi Melody Pool lights // TF-100 Test Kit.
    Re: Intelliflo 011018 Pump-Programming Help Needed
    Sorry this information below is off topic because it is regarding my 011012 Variable Flow pump.
    Program number of gals, number of turn overs per day "1", start and end times. Then the pump will calculated the required GPM automatically.
    Note if it runs automatically at 15 GPM, then try shortening the total run time til it moves the GPM up from 15.
    ie my pump would run 12 hours at 15 gpm but at 16 gpm it runs for only 8 hours.
    Kind of an internal calculation error. Something like it calculates 9 gpm for 12 hours but the slowest GPM the pump will do is 15. So it defaults to 15 gpm for 12, rather then shortening the run time. At least this is how mine works.
    Super happy with how quiet this pump runs at 15 -19 GPM
    Easytouch, Intelliflo, Intellichem, Acid tank with pump, Intellichlor and Autelis network interface.
    Glock30's Avatar
    Apr 2012
    Massachusetts, USA
    90
    OK sounds good.
    How do I calculate/program if I need a timer with my SWG?
    Ooops, just caught what you are saying.....Pump will be off during those times anyway etc.
    THANKS!
    Quote Originally Posted by Glock30
    Here is my set up. It allows me to set a shorter run time for the SWG, while keeping the longest pump run time.
    how-to-control-intellichlor-ic40-w-current-control-relay-t28298.html
