Thread: little stones behind liner
    Mar 2009
    eastern washington state
    275
    Hi everyone, I have a question about my pool liner. I have noticed each year I am getting more and more little gravel/sand like stones between the liner and the wall.. Is this normal and how are they getting there? Most of them are about the size of large grains of rice, one is the size of a pea. My liner is very tight against the wall. Just curious about this.
    live in eastern washington state
    18x36, Vinyl inground 24k
    Hayward 1 hp filter pump
    1 skimmer/2 returns
    24" sand filter, polaris 280 with booster pump.
    Aug 2010
    Central Illinois
    49
    Re: little stones behind liner
    If your walls are steel, it could be surface rust forming.
    DIY 18x36 Vinyl Liner 1Hp 2 speed super pump, Hayward Swim Clear cartridge filter, Pentair 12v Intellibrite 5G, MX8 suction pool cleaner.
    Mar 2009
    275
    no they are ploy. theres seems to be more every year.. was just wondering
    1 skimmer/2 returns
    Feb 2012
    Phoenix, AZ
    728
    Are these near the bottom of the pool? Or the top? Or does it appear to be random?
    Also, did you put a pad down underneath your liner prior to install?
    Mar 2009
    275
    there on the wall, i dont know how they are getting there. there is none on the bottom and yes they did put a pad down...
    1 skimmer/2 returns
    I've noticed the same thing ocurring on the pool ive inherited.The stones or bumps on mine seem to start just where the bottom of the concrete decking would be and go down about a foot or foot and a half all the way around the pool,the the liner is perfectly smooth again after that.I wish i knew how my pool was constructed but i wasnt around when it was built.My biggest fear is that its an ant infestation problem and I'll end up tiny holes in the liner and have to replace it. Through some research i know 5yrs ago the liner was replaced due to fire ants.I'm currently working to rid my pool area and yard of all ants before they chew little holes in this liner.
    Has anyone else dealt with this issue before any help would be appreciated.
    23.5k gallon IG oval w sloped sides w/ concrete deck
    Hayward Pro Series high rate sand filter m#S244T/Rainbow Lifegard inline chlorine feeder m#320/Magnetek 3/4hp booster pump
    Emerson 1.5hp 1081pool motor/Intermatic 24hr dial time switch m#104r/Fiberstars Fiber optics lighting m#6008/and a polaris
