Thread: Cracks in fiberglass steps
    Mar 2012
    Cincinnati, OH
    59
    A new liner is going to be installed today. Yesterday, after the pool was drained, I noticed that there were several cracks in the steps. They appear as nail pops in new drywall, as if something from the back side was pushing into the steps causing a crack. There at least 20 of these. We are replacing the liner because we kept having to put water in it last year, and it is bleached out. Could it be possible these cracks are the problem?
    I have attached a photo of the cracks, as well as the pool drained. I also attached a PDF of the cracks circled, as it is hard to see them in the photo.
    The pool liner, 10 years old, is completely bleached out. I would really like to minimize this happening again, so any advise is appreciated. I am currently attending Pool School.
    Attached Files Attached Files
    18k, 2001 Ft. Wayne 18'x36' oval sport pool with polymer walls, IG, vinyl, 3.5' at ends and 5' in center, Pentair 1 1/2 hp 2-speed pump (new in 2014), Pentair Clean and Clear Plus Cartridge Filter (new in 2015), Pentair IntelliChlor IC40 (new in 2016), new Raypak RP2100 propane heater (installed 4/2013), Mayfair Dolphin Supreme 4 cleaner, 3 jets, 1 floor drain, 1 Polaris jet (never used), 2 skimmers, new Garrett liner (installed 4/2012)
    South Central NJ
    3,192
    Re: Cracks in fiberglass steps
    Looks like a Liner Over Steps configuration. Will the new liner have the optional, thicker step material?
    When liners age, they shrink and lose plasticity. The picture doesn't really show anything though. Without the liner being out of the way, there is no way I know of to see the step wall that has the protrusions. If the protrusions are small and smooth, they can usually be ignored. If not, they will need foam.
    The bleaching was likely due to excessively high levels of chlorine over time and when elevating to shocking levels. I also don't like dark liners as they tend to lighten up over time too. Try not to overshoot shocking levels.
    Scott
    Owner of - PoolGuyNJ LLC
    Mar 2012
    Cincinnati, OH
    59
    The liner did not go over the steps. It is hard to tell because the liner has bleached out so white. They are just normal white acrylic steps from Ft. Wayne Pools. The liner guys said today that they don't think they are cracked enough to be leaking. Guess time will tell.
    Nov 2011
    Moberly,MO
    1,010
    Those appear to be surface cracks not shell cracks. This is common after 15 years or so for some reason.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
