Thread: Aquapure 1400 DC connection
    tomfinch's Avatar
    Mar 2012
    Las Vegas, NV
    52
    There are 3 pins that the DC cable hook up to and my center pin is real loose. Is this normal? It's loose enough to where I feel I could pull it completely out of the cell if I wanted to. The 2 screws are real tight that hold it in place. Any ideas?
    [center:2jd6lb8v]16,000 Gal., Plaster, 3.0 HP Jandy, Polaris UltraFlex2, Aquapure 1400 SWG, Fafco solar panels, Jandy Aqualink[/center:2jd6lb8v]
    tomfinch's Avatar
    Mar 2012
    Las Vegas, NV
    52
    Just an update and question.... I was given an O ring kit to replace the O rings around all 3 pins. The center Pin that connects to the DC cable was corroded on the inside of the cell to the point it was not touching the plates. Not sure why the inside of this one Pin had corrosion and the other 2 didn't. I think I pushed it in far enough that it's touching the plates for now but it's definitely a temporary fix. Is there anyway to replace this Pin so I don't have to spent $500 on a new cell? I'd like to get 1 more year out of this 3 year old cell.
