Results 1 to 10 of 10
Thread: Source barbed fittings for pump drain to install liquidator
    I just purchased a liquidator from Sal and it is on its way. I would like to know where I can source the nylon 3/8 x 1/4 NPT fittings so I can install the out and in lines in my pump and heater drains, versus drilling. Anyone?
    Sal sells the kit with the 3/8" upgrade (thanks), but is replacing the flow control needle valve necessary? If so, where can I source the one recommended on this board.
    Thanks in advance! This forum has been a wealth of knowledge and assistance.
    I have a 14000 gallon pool that was installed last year here in Vegas. Currently running a rainbow chlorinator with trichlor pucks that already have my CH at 660! (I know a partial drain is in order) and CYA at 70 and rising!
    13.5k plaster, with raised spa and waterfall. Pentair VS Pump, Pentair cartridge filter, Pentair automation with 8 function EasyTouch remote. Currently using Rainbow 320, puck chlorinator. Liquidator on the way!
    Apr 2011
    Lynchburg VA
    393
    Re: Source barbed fittings for pump drain to install liquida
    Lowe's has nylon barbed fittings.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Quote Originally Posted by BadOleRoss
    Thanks! Do you know if they sell the speed fittings as well? If not, can you suggest a source for those?
    bibeaud's Avatar
    Aug 2011
    P'Burg NJ
    73
    I got my quick disconnect fittings at Home Depot. Watts PL-3025 or PL-3028.
    11,000 Gal Trilogy "Utopia" Fiberglass Pool, 1HP Jandy Pump, Jandy CS200 Cartridge Filter, Raypak 199k BTU Heater, Liquidator, CMP Off-Line Chlorinator. Cleaners: Polaris 360, Blue Diamond, Poolvernuegen Pressure
    22,548
    Yes, Lowes sells the Speed-fit fittings as well. That's where I got mine.
    Quote Originally Posted by bibeaud
    Wow, you guys are great! Thanks!
    What about the fittings for the float valves on the LQ tank? How are you guys upgrading those to 3/8 hose?
    Pool: IG 22k- 16x32 clipped corners- vinyl liner, w/ a great board. Built in 3/99, new to me 2/2011.
    Equip: Hayward 3600 DE filter, Hayward CL-200 Chlorinator (empty since 7/5/2013).
    K-2006 Test kit with Speedstir
    Located in Cincinnati, OH. TFP lurker since 9/2011, BBB interested since 5/2012 and converted 7/2013.
    22,548
    You keep the same hose so it still fits.
    I received my Liquidator a couple of weeks ago, but when it arrived, it was missing the flow meter. I waited until receiving this part to arrive to install the unit. I began the install this morning, using tips from this forum. I started by adding a gallon of liquid to the tank, so I could mark out the increments of liquid chlorine to be added in the future, and also as a reference as to how much was remaining in the tank. I marked the lines with a black sharpie. I then taped over the lines with a width of duct tape and painted the exterior with white plastic paint, to help prevent degredation of the chlorine due to sunlight. I installed the kit using the 3/8 upgrade and also plumbed the in line from my heater drain port and the out line to my pump drain port. Install was simple and with no leaks! I filled the tank per the instructions and have tested my pool water to see where to set the flow to maintain the chlorine levels. I will come back in about a week and let you know the results, but at this early juncture, I am a Liquidator convert!
    bibeaud's Avatar
    Aug 2011
    P'Burg NJ
    73
    I can email you my install diagram if you have any problems. This is my first season using the LQ. The install was easy using the 2 drain plugs and really fast.
    Thanks!
    David
    Sent from my iPhone using
    Tapatalk
