Thread: The link for "Leslie's Chlorine FAS-DPD Service Test Kit"
    New here ... and reading all I can about pools and how to test for pool chemistry.
    Unfortunately, the link in the OP of the thread BBB for Beginners for "Leslie's Chlorine FAS-DPD Service Test Kit" appears to be dead (the Taylor kit links work fine).
    The closest I could find by searching is 81330 DPD Complete Chlorine Kit, $60
    Quote Originally Posted by Leslies
    Kit contains tests for free, combined, and total chlorine (.5 to 5ppm), total bromine (1 to 10ppm), pH (7.0 to 8.0) with acid and base demand, total alkalinity, calcium hardness, and cyanuric acid.
    May I ask: Is this $60 81330 DPD Complete Chlorine Kit the same as the recommended Leslie's Chlorine FAS-DPD Service Test Kit" kit?
    Silicon Valley, 38,500 gallons in-ground plaster; Sta-Rite System 3 Model S8M150, 259 sqft cartridge 25022-0203S + 191 sqft cartridge #25021-0202S = 450 sqft filter@0.28gpm/sqft = 125 gpm@50psi max. Three 220v Sta-Rite Max-e-Glas II pumps {AO Smith QC1102 1.0x1.65SF for filter + cleaner; SQ1152 1.5x1.47SF for spa jets; square 48Y flange}. 13 Fafco 12'x4' professionally installed "Revolution" solar heating panels + Raypak RP2100 P-R 405A-EP LPG 399,000/hour heater + Compool Lx3600 controller + Infinity 4000 automatic pool cover (120v 3/4 HP motor); both skimmers are NOT filtered & serve only as intake for 9-port water valves (aka cleaner heads) controlling fifteen Paramount PCC2000 3" self-cleaning jets with the optional Debris Containment Canister.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: BBB for Beginners
    Quote Originally Posted by rock
    Unfortunately, the link in the OP for "Leslie's Chlorine FAS-DPD Service Test Kit" appears to be dead.
    No, that is not the same kit.
    Re: The link for "Leslie's Chlorine FAS-DPD Service Test Kit
    They keep changing their web site. The correct kit is now here.
    22,543
    Dude just get the TF-100 and be done with it. It's the best bang for your buck. It contains more of what you actually need as a pool owner.
    Thanks for clarifying the test kit for the comparison of the three most recommended:
    - $68 TFTestkits TF-100
    - $47 Taylor K-2006
    - $71 Leslies Chlorine FAS-DPD Service Test Kit #81329
    Quote Originally Posted by leslies web site
    A complete DPD test kit designed for service people, commercial pool operators and health dept officials interested in economy & portability. Tests for Free & Combined Chlorine (1 drop = 0.2 or 0.5ppm), pH (7.0 - 8.0), Acid Demand, Base Demand, Calcium Hardness, Total Alkalinity and Cyanuric Acid. Includes Titrants to improve accuracy. Uses .75 oz reagents.
