Thread: Summerizing the pool Heater
    Sep 2007
    Gloucester County, NJ
    If I go about opening my pool myself for this first full year of ownership, I wanted to be sure I cover the key things that need to be done for the heater. I have located the owners manual which provides key steps for preparing the heater, including reconnecting the siphon loop to the pressure switch, tighting the mainifold drain, turning the gas on and clearing out any cobwebs and debris. As this is a new heater (September 2007), is there anything else that I really need to make sure is done?
    28,000 gallon gunite/white plaster with 30ft RBB and 2ft sheer descent, 100 sq ft thermaledge, 50sq ft spa w/ 6 jets
    2HP Jandy pump, 60sq ft Jandy DE filter, 400,000 BTU Jandy LX Nat Gas Heater, 2 Jandy color lights + Jandy color spa light, Jandy Aqualink RS6, Jandy AquaPure 1400
    we try to give them a good cleanig with a shop vac. before we start them up
    as well as doing what you have already listed
