Thread: What do I do first?
    What do I do first?
    My 24' Intex swg pool is about full, but I don't know what to put in first. The salt? I have a cheap Walmart pool tester that tests for PH which is 6.8 right now, clorine and bromine (whick I haven't tested). Do I need to get a better test kit? If so, what should I put in the pool till it gets here?
    Re: What do I do first?
    Welcome to TFP!
    Raise the PH up to at least 7.2 with either borax, soda ash, or PH increaser.
    Until you get some CYA in the water, add 2 ppm of chlorine each evening.
    You can add salt any time.
    You also want to start working on raising the CYA level.
    If you order a better test kit now, and assuming you have some kind of chlorine test, the new kit should be there soon enough that you shouldn't have any significant problems.
    May 2011
    Clearwater, FL.
    446
    Hi agr8mom23boiz and welcome to TFP!
    Jason said to add 2ppm each evening. Your probably a little confused at how to do that? You want to use the Pool Calculator to do this, go here and start playing with it to learn how to use it.
    http://www.poolcalculator.com/
    Come back here if you have a questions on how to use it.
    You will want to get some CYA (known as stabilizer) in there soon too.
    CYA will protect the chlorine from the sun using all your chlorine up
    40ppm is where I have mine at in Florida sun.
    Chuck
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
    Thanks guys!! This site is fantastic and that pool calculator is REALLY neat. Following your advice till the TF-50 test kit with Salt Test Strips arrive. Then I guess I follow the procedure in the Water Balance for SWG's article. Things are starting to make a little more sense now. Thanks for all your help.
    22,550
    Another welcome to TFP!
    If you've figured out the pool calculator you're a long way down the road.
    You'll need about a quart of bleach to add 2 ppm FC.
