Thread: AQUA Trol Question
    AQUA Trol Question
    Hello All,
    A couple of quick questions about the aqua troll SWG for above ground pools.
    1) Can the HP model also be mounted vertically?
    2) I am also considering the RJ which only mounts vertically on the return. The Aqual Trol Box is five feet away. Does the cable that goes from the AQ Box to the cell need to be buried or can it lay on top of the ground?
    Thanks
    Re: AQUA Trol Question
    Yes, either model can be mounted vertically.
    The cable can lie on the ground, but you don't want it anywhere it can get walked on. Commonly one would run it alone a hose, or something else that prevents it from getting stepped on or tripped over.
    Thanks for the quick response!
