Thread: COPING AND LINER REPLACEMENT
    My pool is a 20x40 ig beaded liner and wanted to replace coping and not sure how to do so my coping on there now is an old plastic with aa top on it with ridges and is attached to a plate underneath with blots. i wanted to install a new bullnose coping but not sure if i need a certain kind or style for my pool
    20x40 IG 24000 gallons approx, sand filter LONDON, CANADA
    South Central NJ
    3,192
    Re: COPING AND LINER REPLACEMENT
    Changing coping is often pool dependent. Not all liner pools are the same. Some are steel, some are stainless, some are resin, and some are wood walled. It's sort of like two different makes of cars. They won't be able to use the same oil filters or spark plugs.
    Scott
    Owner of - PoolGuyNJ LLC
    The pool has steel walls trying to post pictures but dont know how???
