Thread: Best Robot for my Vinyl liner ?????? Help
    NJ
    291
    I just replaced the liner on my 20x40 IG pool and would like to know which robotic cleaner will be the safest for use on the liner. I have a Blue Pearl that has worked well for about five years. I need new belts from the motor to the drive section and the filter bag could probably use replacing. Before I spend the money on parts I want to know if there is something better out there. While I cannot prove it I believe the unit wore down the liner near the water surface as the pattern was very faded there and where the walls met the floor. Is there something that will be more gentle on the liner?
    20x40 IG vinyl, heatpump and solar and 3 siberian huskies, 10kw PV solar electric system. Nikon Photographer D800e dSLR.
    30,403
    Re: Best Robot for my Vinyl liner ?????? Help
    I can't help much but have a comment on the faded liner. My Father in law got a new liner and, within a year, the pattern was worn where the floor meets the walls and in the shallow end where his suction side vacuum spends most of it's time.
    My Blue diamond has been slipping and sliding and rubbing at the point where the walls and floor meets for four years and I see no wear whatsoever.
    I suspect it is the quality of the imprint on the liner rather than the cleaner doing the damage.
    Oct 2007
    Parkland, FL
    752
    Quote Originally Posted by kirbinster
    the belts are minor replacement costs although a bit of a pain to actually change, the filter is a minor replacement cost too. you really aren't going to get much better in a cleaner. I would stick with that. the only thing you don't have is a warranty.
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    NJ
    291
    I think I should probably replace the blue drive belts and the roller pads as well. Will have to figure what that will all cost. I think these two parts being worn may be what is causing the problem.
    NJ
    291
    Well I guess it was a good idea to replace the roller pads. I had not realized how much they had worn down. I think the edge near the traction wheels was actually scraping along the liner. You can see in the pictures that the old pad had worn down to about half the thickness of the new ones. Never noticed this without taking the unit apart as they appeared to be in good condition without much wear.
