Thread: Dealing with the 4 Diving board bolts
    Central Connecticut
    159
    I have a relative with an in-ground pool who just removed their diving board. They had the 4 bolts cut down close to the cement patio level. Now we want to cover the tops of the bolts. Is there any product that would be good to cover the tops of the bolts that would also adhere to the cement so that no one steps on the severed bolts?
    Thanks
    Rich
    18x36 IG 26,000 gal, Vinyl Liner, 24" Sand filter Hayward S224T, Jandy AE3000 heatpump and 1.5 HP SuperPump. Circupool RJ45 SWG
    I would recommend drilling them out and then either concreting the holes or using a concrete caulk.
    16 x 42 x 24 IG Vinyl True-L, 27,000 gallons, full width steel steps, 8' Cuddle cove swimout, 2 X Colorlogic 4.0 LEDs, Hayward Tristar 1 hp 2-speed pump, Hayward SwimClear C3025 Cartridge filter, Hayward Aqua-Plus PL-PLUS Controls + Chlorination, Hayward low-Nox 400K BTU heater, Tigershark QC, TF-100 test kit
