Thread: Hi from Delta, Canada
    zedcaster's Avatar
    Apr 2012
    Delta B.C. Canada
    7
    Hi all, I live in sunny Delta, Canada - about 4 blocks north of Washington state, and about 20 miles south of Vancouver, B.C. We bought a house last fall with a pool, and a hot tub. I've never had either before, and I've already started having "challenges" with both.
    The house was built in 1969 and the pool is probably of the same era, but I don't know. It's an ingound gunnite pool (or a "See-ment pond" as Jethro might have called it). Although the pool has been trouble free, and I have a pool service looking after it, I'm a hands on guy and have started nosing around. First issue is there's no weir on the skimmer so I'm hunting for a replacement. I'll post a query in the appropriate topic on that problem shortly, as it's not a simple fix since I can't identify the skimmer.
    On the hot tub front - it croaked yesterday - the spa pack frapped out and has to be replaced. Bummer, I've spent the winter getting into the hot tub habit and suddenly I have to go cold turkey. I ordered a replacement today and should have it installed ASAP.
    There's more...but that's why I joined up...to get to the bottom of the pool (and the hot tub)! Anyway, nice place ya got here.
    See ya 'round.
    Z
    New to pool/spa ownership dealing with;
    In ground gunnite pool recent plaster and coping- 1970's vintage. Comes with a mystery skimmer, capped main drain, two pressure jets, Sand filter, one pump, natural gas heater.
    Pacific Spa Hot tub 2 pump, and circ, electric heat w/ Gecko in.xe spa pack
    30,432
    Re: Hi from Delta, Canada
    Welcome to the forum. You'll find a ton of help and a lot of nice pool owners here.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Welcome! Post some pictures of the stuff your looking for and I'm sure somebody will be able to help.
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    Butterfly's Avatar
    South Carolina
    10,045
    You're done SLAMing when:
    Feb 2008
    Denton, TX
    5,061
    Welcome to TFP!
