Thread: CYA on a hot day - More the better??
    Apr 2012
    56
    Hey guys, just drained my pool. Going to swim in it for the first time tomorrow!
    I dumped a gallon of 10% chlorine in it this morning before work, and here are my test results when I got home tonight:
    FC: 4 (QUESTION: The drop-test showed 5-10+ range (color was orange-ish), but FAS/DPD showed 4.5ppm... Is my Taylor test kit I just got with my TF-100 kit bad?)
    pH: 7.8
    T/A: 120
    CYA: 30-40
    Temp: 76 degrees
    So, my question is mostly that I live in Tucson, Arizona, where it gets HOT in the summer. Would having a higher CYA be to my benefit?
    *My pool is more like 12,000 gallons. I need to fix my sig...
    IGP, concrete and plaster. House was built in 1982, pool appears to have been installed then. 15,000 gallons. Hayward C1200 filter. 1HP pump.
    Re: CYA on a hot day - More the better??
    Higher CYA is good up to a point. As the CYA gets higher you have more trouble if you get algae, but otherwise use less chlorine. In practice CYA at 50 is a good maximum for most people, perhaps 60 if you get an especially large amount of direct sunlight.
    Apr 2012
    56
    Ok, thanks. Mine gets a lot of morning sun and about half the pool is shaded all afternoon. So ~40 CYA is probably pretty good for me then.
    Random question, can I dump the test chemicals back into the pool?
    22,553
    That's not recommended. Some of those reagents are not good for you and shouldn't be put in the pool water.
    Apr 2012
    56
    Yeah I suppose that makes sense. I've seen other people throw them back in the pool and I always thought that seemed a little weird... To the ground they go.
    Jun 2008
    Marana, AZ
    347
    I live in Tucson myself. (Well, a suburb.) Yeah, with the amount of sunlight we get, a fairly high CYA works well. I keep mine about 40. I have let it go up to about 60, but when you do that, you do have to keep the chlorine up. I find that with staying with the recommended chlorine levels to the CYA levels I have little problems with algae, even during monsoons. In fact, I think the only algae problems I've had is when the chlorine drops a little low. Now, if I could find a way to keep the dust out...
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
