Results 1 to 11 of 11
Thread: Upright support movement when filling Intex
    18x52 Ultraframe
    While the pool is filling, do you constantly adjust the supports to assure they are vertical? After a certain amount of water is in there I assume it will be to heavy to adjust the supports.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Upright support movement when filling Intex
    Good question; I would assume so, but lets see if any intex owners will comment...
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    My fill process:
    1. Setup pool in aprox. position.
    2. Put about 1-2" of water in, smooth out wrinkles and adjust pool placement.
    3. Put more water in, checking for wrinkles and leg positions (side to side, in and out)
    4. Fill with water, check and adjust water balance.
    5. Have fun!
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    racerboy6996's Avatar
    Aug 2010
    Albemarle, NC
    103
    when we installed our 16ft metal frame intex, i let it fill a foot or so & adjusted the legs & then did it again at 2 & 3ft. You are correct, once it is almost full you wont be able to easily adjust the legs. I did have one leg that due to sinking went out of level when it was almost full & I used a rubber mallet to "gently" adjust it. But I am not recommending that as the preferred method
    Intex 16ftx32ftx52in rectangular / Hayward 2 speed pump / Hayward 21in sand filter / Intex SWG / still saying solar panels coming next year
    Jul 2011
    Winnipeg, Canada
    11
    What mcoonan has said is a good way to fill the pool. If your site is level, you should not have to adjust the legs to much. There still is always some needed though. I kept an eye on mine when filling. If I remember correctly, at about half full and I could not adjust anymore.
    15'x52" Summer Escapes AGP with 1000GPH pump and side skimmer/filter system
    I am a newbie.
    So the pads should be on top of the ground, not dug in?
    intex 18 x 9
    4500 gallons
    22,550
    The top of the pads should be level with the top of the ground. so they should be sunk in the ground.
    If you sink the pads in the ground how do you move them?
    intex 18 x 9
    4500 gallons
    The pads that should be in the ground are pavers that the pool legs should stand on. If you mean the "foot" of the leg when you say "pad", that should not be buried but should be atop the paver.
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    Ok, I think I get it thanks.
    So as I level I should figure out where the pavers go and make them flush and level. The intex installation instructions and video don't seem to give any measurments.
    intex 18 x 9
    4500 gallons
    22,550
    That's correct.
