Thread: Trying to open the pool myself...motor just hums
    Hello!
    I'm attempting to open our salt water pool on my own this year. (I'm reminded of the old joke about the lawyer who defends himself having a fool for a client.) Anyway, I THINK I have covered all the preliminaries.
    Cover off.
    Filled up pool to the appropriate level.
    Installed filter baskets in skimmer and at pump
    Removed plug from the skimmer and replaced the return jet plugs with "eye balls."
    Re-inserted the plugs under the pump and its basket (there were 2) and at the base of the sand filter.
    Filled the pump basket with water to prime it. Replaced the lid.
    Turned the filter "dial" to backwash (from "winterize.)
    And powered up the motor (it's hardwired into the electrical outlet next to it), only to hear the dreaded hummmmmm with no pumping or suction.
    I've read through many of the posts and know that many humming motors are the result of a clogged impeller or a faulty capacitor. It's pitch black right now, so I can't check those until morning.
    What I'm wondering is: Have I missed a step in the pool opening requirements? Could that be part of the motor's problem?
    Many thanks for any insight!
    72,000 litre (19,000 US gallon)
    In-ground
    Saltwater
    Vinyl liner
    Living and swimming in beautiful British Columbia.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Trying to open the pool myself...motor just hums
    Quote Originally Posted by skali
    Sounds to me like you haven't missed anything. Does the motor shaft turn freely? You can check this by having the power off to the motor and rotating the impeller, or (on some motors) you can remove the rear cover to the motor and turn the shaft directly. The shaft should move freely.
    Sometimes the relay will get stuck and cause that dreaded hum also. It is spring loaded and you may be able to tap on it and get it to release.
    24' x 52" Round AG Pool, Hayward Aqua-trol SWCG, Hayward Pro Series High Rate Sand Filter, Hayward Power Flow LX Pump 1HP 60GPM, Hayward H100ID Heater.
    If the motor turns freely and the relay is not stuck it's probably time for a start capacitor. I found a local motor shop that sells them for $12.
    16x32 Oval In-ground Vinyl, ~17,000 gallons, Hayward 1hp Superpump, Hayward S245T Sand Filter
    Worn out sand? sand-filter-expert-help-t30049.html
    Drain the easy way: cyanuric-acid-blues-draining-pool-t43843.html
    http://tftestkits.net/splash-page.html , pool-school/chlorine_cya_chart_shock , pool-school/shocking_your_pool
