Thread: Which levels to use
    Feb 2012
    Greenville Indiana
    35
    Which levels to use
    I am setting my pool up as a swg pool but I will be dosing bleach or pool store lquid chlorine untill the swg is purchased in early fall or next years opening. Right now I have about 3200ppm salt in, and the boric acid is on the way. Cya is at 50, fc 4.5, ph 7.3, ta 210, ch 210. My tap water is even worse! I found threads reccomending using the swg levels, and others to use the fresh water list. Right now the salt and boric acid is mainly to improve feel.
    TIA Eric
    27' x 54" Cameo by Backyard Leisure (Wilbar) 17,200 gallon
    Hayward S180T filter with a 1.5hp pump
    Zodiac Barracuda Ranger vacuum
    GLI fencing around top rail
    All piping hard piped (that is what I do far a living!)
    six 2'x20' solar panels
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Which levels to use
    Unless you are running a swg, use the bleach recommended levels regardless of salt concentration.
    Mar 2009
    Huntsville, AL
    156
    You might want to lower your TA before adding borates, I believe it will be harder to adjust after the borates are in. Here is a link to the instructions for adding borates:
    http://www.troublefreepool.com/so-yo...how-t4921.html
    And here is another link on how to lower TA:
    http://www.troublefreepool.com/pool-...l%20alkalinity
    27K gal, IG vinyl, 1.5 HP pump, 24" sand filter, Goldline Aqua Plus SWG
