Thread: Concrete "curb" around outside of aboveground pool
    BigEyesLittleWallet's Avatar
    Aug 2010
    Metamora IL
    20
    Is there any reason I shouldn't create a form (3.5" high 6" deep) that goes around the outside base of my above ground pool and fill it with concrete.
    I'm trying to make sure water can't get under the pool to wash the sand out (Overfilling the pool, fill hose coming out of the pool, ect...)
    I have field tile about 1.5 feet away from the pool to take any water away.
    bad idea? thoughts?
    18'x45'x52"" AG Pool. (22,200 gals)
    Pentair Sand Dollar Sand Filter SD-60
    1.5 hp pump
    CompuPool Saltwater Chlorinator 26K Gallon CPSC24
    TF-100 Test Kit
    30,432
    Re: Concrete "curb" around outside of aboveground pool
    I don't think that ever been brought up here on the forum. It seems to me it certainly wouldn't be able to seal to the out wall of the pool so mold, dirt, algae, etc. would begin to grow between the concrete and the pool wall and you couldn't clean it out.
    I'm not so sure that makes it bad to do but it's something to think about.
    Samantha_in_AL's Avatar
    Apr 2010
    Altoona, AL
    242
    We were concerned about water getting underneath our AGP when it was first installed. My husband dug a trench all the way around it, lined it with thick plastic and installed black flexible pipe with holes in it. He t'd it off and connected another pipe for the water to drain down the hill away from the pool. Then he used landscaping timbers to make a border and covered it all with gravel. It looks like a sidewalk going around the pool. It works great. It also keeps weeds and grass from growing too close too the pool.
    AG 18' X 52" Round Pacifica Pool w/ Metal Diamond Unibead Liner. Installed in March 2007.
    2.5 HP Baquapure 2 Speed Pump, 200 GPM Waterway ProClean Cartridge Filter System.
    Former Baquacil user
    Converted to BBB in Fall of 2009 - Now I have a truly trouble free pool!
    Aug 2010
    Metamora IL
    20
    Thanks for your help
    1.5 hp pump
    TF-100 Test Kit
    Aug 2017
    Moncks Corner
    1
    What if the concrete was used under the pool stanchions and outside the pool? Basically a donut of concrete not under pool liner, just the outside ring of a 24' round above ground pool. Would that work and if so, how thick would the concrete need to be?
