Results 1 to 12 of 12
Thread: Confused
    Mar 2012
    Fayetteville, NC
    10
    Confused
    Did my 1st tests with TF100 last night.
    13200 gal
    FC 2.5
    PH 7.8
    TA 130
    CH250
    CYA 50
    I wanted to go up to 8 FC, Pool Calculater said add 151oz of 6% bleach. I added whole 182oz of Wal-Mart 6% bleach. Tests now are
    FC 14
    PH 7.8
    CYA 50
    CC was 0 on both tests.
    Why did it raise the FC so much?? Great website and forum, BTW. Pool was installed in November so I'm still learning
    14x28 13,200 gal IG Vinyl
    Pentair SD60 60gpm
    Pentair SuperFlo 3/4hp
    2 Aqua Genie Skimmers
    TF100
    Re: Confused
    Welcome to TFP!
    There are several ways that could happen. The most likely is you entered the the wrong size for your pool, larger than it actually is, into the Pool Calculator.
    30,419
    Re: Confused
    Welcome to the forum. Well, you used the calculator correctly, I think. How sure are you on the size of your pool?
    Mar 2012
    Fayetteville, NC
    10
    Re: Confused
    It's 14x28 in ground vinyl. Installer said it was 13,200 gallons
    Pentair SD60 60gpm
    TF100
    30,419
    Re: Confused
    Well, that sounds about right, also. The next best guess is if you are new to the test kit, a testing error is a common issue. review the steps....did you multiply X.5 to get the answer?
    Mar 2012
    Fayetteville, NC
    10
    Re: Confused
    It was 28 drops. The test was taken 2.5 hrs later. Pump is running 24-7 til I get a timer this weekend. I'll test again tomorrow when I get off work
    Pentair SD60 60gpm
    TF100
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Confused
    Welcome to tfp, darylfoot
    Quote Originally Posted by darylfoot
    This has me stumped (a possibly silly question for you...you don't have a swg or other chlorinator running, or perhaps a floater or forgotten pucks in skimmer by any chance?)...let us know what your next results are.
    May 2009
    Dallas, TX
    782
    Re: Confused
    Haven't I read somewhere on the forum that bleach is commonly stronger than the % listed on the label? Stronger bleach together with a slightly over estimated pool volume could cause the anomaly...
    20K gal IG plaster pool, Manually chlorinated with bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
    30,419
    Re: Confused
    No, I think you have to be concerned that it is possibly weaker but seldom, if ever, stronger.
    MY LQ guy said the 12% I use is manufactured at around 14% but that it quickly starts to lose strength and by the time it gets to the consumer, is right around 12ppm......and they buy chlorine twice weekly.
    However, that 12% chlorine weakens MUCH quicker than 6% so it will last on the shelves of the store and in your garage quite a bit longer (weeks) but it does slowly weaken.
    I do remember a chart someone posted showing the degradation but I searched and didn't find.
    Mar 2012
    Fayetteville, NC
    10
    Re: Confused
    OK, checked my FC tonight and it was at 5. I'll check again tomorrow and see what's up...
    Pentair SD60 60gpm
    TF100
    Re: Confused
    http://www.powellfab.com/technical_info ... tware.aspx
    The Powell Sodium Hypochlorite Decomposition Program generates graphs and tables illustrating the decomposition of sodium hypochlorite based on the user's selected temperature, starting weight, and bleach quality.
    The user can automatically generate tables and graphs depicting the decomposition of sodium hypochlorite over time (between 1 and 360 days) for up to four various scenarios based on the selected temperatures, starting weights, and quality of bleach (filtered or non-filtered).
    The Powell Sodium Hypochlorite Decomposition Program is available for free.
    Support the site
    Jun 2011
    Long Beach, CA
    2,784
    Re: Confused
    When you add any chemicals make sure you test the water again 1-2 hours after adding the chemical. If you don't get the results you expect then we'll go from there.
    I always add more water to my test cylinder after running the FC test to make sure the water turns pink. If you don't put enough powder in the test, the water will not turn pink and the test should be redone with more powder than the first test.
